Question about VCRs
Orion model vpdc connection problem
I bought an orion model vpdc recorder on the internet the advertisement did not say anything about the limitations on connections on this model. But I received the vcr and the installation instructions pasted on the vcr says "this player will only operate onuhf capable tvs . Incidentally this seems to have been rented by the seller . My tv which I bought recently from Dick smith is model noG6021. it si a colour tv .HOw do I connect the vcr to the tv as I have a surveillance camera connected .
  • 254 Answers
Re: orion model vpdc connection problem
Most, if not all, TV sets which have a tuner section (will tune in individual channels either off an antenna, cable system etc.) should be UHF capable. UHF channels are approximately channels 14 - 83 of the standard broadcast spectrum, unless this has now changed with HDTV or other RF spectrum changes by the FCC. These channels are not the same as the cable channels, for which the mode of the TV set must be set.
Anyway, you will connect the VCR to the RF input of the TV, and set the TV for non-cable mode (broadcast). You will likely need to set the TV for a particular channel which matches what the VCR sends the signal out on.
I assume also the VCR doesn't have composite video out & audio out jacks on it? If it does, these hookups can be made to matching connections on the TV.
Hope this helps.
Posted on Nov 06, 2007
0 characters
3 Points
Cannot get video on my Orion model VRO 211B
Could be a connection problem. Pins on plugs can become bent or damaged, sometimes it is the socket that the plug fits into that becomes damaged. Try a different connection lead.
Dec 26, 2015 | Orion VR0211B Video Cassette Recorder...
Digital programing
By the look of it you would need to connect a digital set box to it to record any TV programs, seeing that most countries are switching off or have switched off analogue TV. The video would then pass any signal it had recorded via a scart lead to any TV with one of those sockets.
Feb 11, 2014 | Orion VR0220 VCR
I need a user manual for an orion video recorder model d1050a
Check or call 618 392 7000 or faxem at 618 392 7100. Tell them the Hamburgerman said so. I own and operate a restaurant and also your Orion Service center. I repair between orders. Your burger to go, is ready, and you can pickup your tv!
Sep 04, 2009 | VCRs
Need the user guide for Orion vr213 vhs player:
Sounds like the heads need cleanning.
Jan 20, 2009 | VCRs
Orion VCR 213 will not record with converter box
The chain of cabling that you have should go like this; First in line should be the wall supplying the cable box. Then, the cable box connects to the VCR, then the out of the VCR should go to the TV. Select whatever channel you desire, make sure that the VCR is on Channel 3 or 4, (Whichever the back of the cable box is set) then select 3,4 or line/AUX to see the results....accordianman
Dec 12, 2008 | Orion VR213 VHS VCR
Orion vcr recording
I'm sorry, but the speed cannot be changed without the remote.
Nov 07, 2008 | Orion VR213 VHS VCR
Orion D1050
need remote contro'
Feb 07, 2008 | Orion VR213 VHS VCR
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Apr 24, 2007 | Orion VR0419 VHS VCR
VCRs Logo
94 people viewed this question
Top VCRs Experts
alexander woolfolk
alexander woolfolk
Are you a VCR Expert? Answer questions, earn points and help others
