Vulcan wall furnace about 12 years old manfacturers #2284 fan became intermittent before completely shutting down. pilot works fine just the fan stopped working
  • martindarman Jun 27, 2009
    i checked the blower resistor and its reading fine approx .7kohms(boost speed) upto 1.8kohms(slow speed) any other suggestions?
  • martindarman Jul 01, 2009
    sorry seth for late reply ive been crook. Got no heater so i caught a cold. The irony of it all : )
    ok i have 4 wires going to the motor.
    2 for the windings which reads .5 ohms.
    1 for the switching from thermostat
    1 for ground
    thermostat is fine. when heated it goes to short.
    i was thinking the capacitor as it looks like this circuit requires a kind of exciter to kick the motor into moving. so i hooked it all up and gave it a finger push (the same purpose of the capacitor)......... nothing
    i'm gonna kick the thing in the guts and buy another
    Sergeant:
  • 353 Answers
Ever oil the motor?
ever clean the dust out?
good luck!
Posted on Jul 01, 2009
  • 334 Answers
Hey there, have you tried to ohm out the motor itself? It's possible the internal overloads in the fan motor were opening and closing due to winding break down or bearing drag and finally failed or the windings themselves opened. No continuity across the windings when the motor is cool means a bad motor. Another thing to look at is the relay that turns the fan on. Check the continuity accross the contacts when they close. They can tend to build up dirt and carbon on them. Let me know what you find out. If all looks ok see if you can get an amp draw reading on the motor to see if it is trying to start.
seth
Posted on Jun 27, 2009
  • seth veloso Jun 27, 2009
    Hey, I got no response from ya I hope all is good to go for ya
    seth
  • 854 Answers
Well try to check the blower fan resistor on your unit... it is possible that this part is now faulty and not working...
Posted on Jun 25, 2009
Vulcan Quasar wall furnace, pilot will lit and burner starts but goes out after a few minutes. sometimes pilot will relight but most often fails to light till unit cools down. Any suggestions?
You may need a new thermocouple if you have been able to light it before.It is located above the pilot lite and needs to get hot to keep the gas flowing.You can pick up a universal thermocouple a the local hard ware store.Shut the gas off,unscrew the coupling nut and remove the old one.Bend the the new one like the old one and replace.Try not to kink the new one.Good luck and thanks for choosing FixYa.com.
May 15, 2011 | Heating & Cooling
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Jan 19, 2010 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Heating & Cooling Logo
254 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
