Question about Canon MV550i Mini DV Digital Camcorder
Eating tape my canon keeps on chewing tapes from different makes when rewinding it from end of tape till beginning. Tips on best tapes or what to do would be welcome, thanks, Jorg
  • Koolkul Dec 10, 2007
    Mine does the same when I rewind. Although I did read somewhere that with a new tape it was best to wind and rewind the tape to get the tension right??? I need to try this out.
  • Anonymous Jan 01, 2008
    CANON MV550i
    WAS ABOUT TWO WEEKS OUT OF GUARANTEE WHEN THIS HAPPENED
    PLAY IS OK
    FORWARD ON PLAY IS OK
    REW ON PLAY IS OK
    FAST REWIND CHEW
    FAST FORWARD CHEW
    THIS SEEMS STRANGE AS TAPE SHOULD BE UNLACED FOR FAST FUNCTION?
    THEREFORE HOW DOES A CHEW OCCUR?
    OR DOES MECHANISM FUNCTION LIKE BETAMAX? i.e. LACED FOR ALL FUNCTIONS?
    I'M SURE THIS WOULD NOT BE AN ECONOMIC REPAIR BY A THIRD PARTY
    BUT IF I KNEW EXACTLY WHAT THE PROBLEM WAS AND IF ANY REPLACEMENT PART NEEDED WAS SENSIBLY PRICED (AND AVAILABLE) I'D FIX IT MYSELF
Diferent speed on REW and FF drum. Must cleans tape way
Posted on Mar 24, 2008
The cassette keeps eating my tapes, what can I do???
You need to determine what is chewing the tape up. Most cassette doors clip off, this can often show the head and pinch rollers when they come into play. The pinch roller (the rubber one) is often the biggest cause of chewed tapes. But often it's the Take Up Reel that is not moving forward, so the tape is taken out of the cassette by the roller and spews out into the deck, getting tangled up in the roller. The roller itself can become worn and therefore doesn't make proper contact with the idler, or the idler (metal bar the roller pushes against) isn't turning caused by a belt that's broken.
The only way really is to observe what the tape is doing, but since this by definition means the tape could be chewed up, means you have to use an old tape that doesn't contain anything good on it. Make certain you can view as much of the workings of the deck mechanism as possible when using a test tape.
Since you don't mention the make or model number that is the best advise that any expert on here can give you.
Mar 12, 2015 | Audio Players & Recorders
Tip
Tape tips
try this:
1. make sure the tape is not loose - turn one end to tighten
2. make sure the head is clean - try a qtip or slightly damp swap long enough to reach and clean the head (silver drum but please be extra careful not to use to much force there is a litte haed that reads the tape and if you get any strands caught on here it will be hard to get out) the head will spin but clean and hold as much as possible because the head is harder to clean while spinning and the head is in between that has a very small slot to see it but it is close to the gapped seem of the haed
3. if you can fwd and rewind tape
4. make sure nothing is stuck in like and torn tape pieces
now sometime tapes of 120m are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
on Nov 12, 2008 | Sony P6-120MP 8mm Tape
My canon xl1s eats tapes in vcr mode while in rewind. this has happened with two different tapes, sony dvc tapes.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jun 21, 2011 | Canon XL1S Mini DV Digital Camcorder
Eating tape when I try and record or rewind tape
its sounds like the tape deck needs to be cleaned
Apr 13, 2010 | Canon GL2 Mini DV Digital Camcorder
Video Tapes will not rewind
The belts and idler eed to be replaced. The rubber parts have become slippery. WIth the increased load at the end of the tape, the rubber just does not have enough grip to keep the reels moving.
This should not be a really expensive fix. I usually overhaul units ilke this for about $50 + parts. Figure anywhere from $10-$20 for parts.
Dan
Mar 18, 2009 | GE VG4056 VHS VCR
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Canon MV500
Perhaps this will help some. I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation applies to you, try the following, and make sure that in the future you don't fully rewind your tapes! Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, near the top (that is, opposite the side where the tape is exposed), locate the notch between the two spools (the "wheels"). The notch will have a spring-loaded slider inside, which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.) Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Dec 11, 2007 | Canon Optura 20 Mini DV Digital Camcorder
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
Canon MV550i Mini DV Digital Camcorder Logo
272 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
