Question about Dryers
Dryer is squeking badly and drum seems to be loose. Dryer is about 9 old.
    Sergeant:
  • 199 Answers
Ther are rollers that hold the drum up and a big belt that wraps around the drum and the motor pully it sounds like one of the rollers has broken and has lessened the tension on the belt. pull the dryer out and take the back off. unplug first. giggle the drum and find what is loose the belt can be wareing out too. or a bracket may be broke that holds the pulley
Posted on Jun 25, 2009
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
Just replaced high imit thermal fuse. The dryer belt squeks after 30 minutes on high manual mode. It seems the dryer is running much hotter than usual maybe causing the belt to squek. Any idea???
You may possibly have a bad temp control stuck on that caused the hi limit to open in the first place. That may be why you have a hotter than normal dryer. Temp controls are usually near the hi limit. A round disk with either 2 or sometime 4 wires hooked to it. Also check for a possible block vent keeping the hot air from venting outside.
Mar 20, 2015 | Dryers
Squekness when drum turns
Unplug the dryer. 4f3e336.jpgYou need to pop the top. Get the front off.9097534.jpg
Remove the drum and check the rollers and idler.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 20, 2010 | Maytag SDG3606A Gas Dryer
Very loud squeking from dryer
Most of the time that dryer drum bearing WE3X75 is the problem. You need to remove the drum to replace it.
Feb 08, 2010 | Dryers
New Maytag dryer belt too loose
is the idler pulley have enough tension on it,the tensioner on these can get bad and not put enough tension on the belt,push on it,it should take some force to move it,if you can get your fingers under the belt around the drum without much effort then replace the idler pulley and tensioner
Jan 31, 2010 | Dryers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Why is my maytag dyer has a squeking sound
your roller wheels may be going bad. The drum rides on them and they have bearings in the middle that eventually wear out and make quite a racket. OR: your belt around the drum is getting old and will eventually break.
Jul 16, 2008 | Dryers
Dryers Logo
93 people viewed this question
Top Dryers Experts
