Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
I have a rockford fosgate x7 amp and the fan stop working and a little while after playing it shut off what do you think
    Novelist:
  • 131 Answers
Replace the fan in the amp, sounds like the amp is overheating and the cut off is kicking in... you can try the amp while not driving and the car parked, put a fan, like a desk fan where the amp is so it flows over the amp fins, and run the amp turn it up and let it work, see if it still shuts off after that, if so then it could be something internal nut sounds like it is the fan to me... and i have worked with many an amp and system in cars and trucks... hope this helps you
Posted on Jun 25, 2009
Instructions on how to install a Rockford Fosgate RF X7 amplifier in vehicle?
Here is a wiring diagram. Second from right is positive and third is ground
Jan 06, 2018 | Rockford Fosgate Car Audio & Video
My Rockford Fosgate type rf x7 will not power on. help
Does it try to power up and blow fuse? Does it power up and stay in protect? Is it completely dead and does nothing?
Aug 24, 2016 | Rockford Fosgate Car Audio & Video
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
It will NOT work!
You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate Punch 360.2
If the wires were touching then the amp overworked itself into a early grave..What happends when they touch is the amp goes from seeing a 4 ohm load to seeing a 0 ohm load. You can imagine why this would be bad for a amp...usually the amp should shut off to protect from damage and I would assume that Rockford would. Right now im having a similar problem..I suggest your call rockford and ask to talk to a technical advisor ( the name escapes me) and ask him what he thinks.
Mar 17, 2007 | Rockford Fosgate Power 360.2 Car Audio...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
209 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
