Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
