Humidifier is running but not extracting water. Could the problem be in the coils? I cleaned the filter. The unit is 10 years old. Has it seen better days? Any help would be appreciated.
The problem is probably due to dirty or clogged coils. Cleaning the coils to a dehumidifier is similar to cleaning the coils on an air conditioner. It really depends on how dirty the coils are. If it is not too dirty you can use a shop vacuum with a brush attachment. If it is really dirty you will have to use a non acidic hvac coil cleaner or you can use a household cleaner like Simple Green that has been diluted 1:1 with water and placed in a spray bottle. Spray the solution on and let it sit for 5-10 minutes. Make sure you unplug the unit before doing anything. If you use Simple Green make sure you spray it down with clean water. If you use an hvac type coil cleaner some do not require rinsing. Follow the directions on the product exactly. You might have to use a brush or even a putty knife if the coil is totally clogged. Be careful you do not damage the coil. Good luck!
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if...
(More)
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if purchased brand new and if this is a good product. The asking price is $275.00 with 50 ft of hose to drain outside. Thank You for your help, Kristina
small basement efficiency that is not occupied during cold months, and accumulates mold and paint...
(More)
small basement efficiency that is not occupied during cold months, and accumulates mold and paint damage while unoccupied
outbuilding attached to house has severe condensation problems it is constructed of brick walls...
(More)
outbuilding attached to house has severe condensation problems it is constructed of brick walls concrete floor and ceilings started to smell strongly any solutions
my filter and the inside keep getting caked with ice even though my basement never gets below 55...
(More)
my filter and the inside keep getting caked with ice even though my basement never gets below 55 degrees
