I can safely say that the components are still in good working order, just because it's flashing doesn't necisarily mean the components are ruined, but i can see how it's distracting, my suggestion either paint over the defective led
I can safely say that the components are still in good working order, just because it's flashing doesn't necisarily mean the components are ruined, but i can see how it's distracting, my suggestion either paint over the defective led or have it disabled
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
SOURCE: Hi I have a sony Wega tv model # KV-27FS12. When i
G'Day!
The TV can be fixed as long as the parts needed are still available from Sony. However, as far as trying to determine what part(s) are needed, I wouldn't listen to anyone other than a tech who's actually taken a look at the set or has worked on one with the exact same problem. If you make a call to a local repair shop, especially one that advertises repairing Sony, a nice guy will at least give you a ball park figure as to what the repair will cost you.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: Sony trinitron WEGA won't turn on and standby
Unfortunately, what you're describing is a repair issue. You won't be
able to address the problem with troubleshooting. There is a part
inside the TV that needs to be replaced. If you're under warranty,
this will cost you nothing. If you're not under warranty the cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher.
Visit the link below so you can talk to Sony either on the phone or via online chat for your full range of options.
http://esupport.sony.com/US/perl/support-contacts.pl?
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Testimonial: "Thank you so much"
SOURCE: Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
