Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
NO CONNECTION (LAN) on Brother MFC-440CN
Only got this printer (Brother MFC-440CN) a few months ago. Until today, I have been able to both PRINT and SCAN using the built-in Network card. For some reason I was trying to SCAN a document today, but it doesnt work. The printer gives error message 'NO CONNECTION' and whenever I run SCAN from the Control Centre Software, and choose start, it times out and gives me an error message.
  • musclefx Jun 25, 2009
    Prior to posting my message, I had already checked all physical connections and looked for loose cables. I even tried NEW cables. There was no IP Conflict either. Even looked at possible issues with firewall... nothing of concern there either. Aaaargh!!!!!
    Not sure what else to look for.
    OK, tried setting STATIC IP ADDRESS, can print test page.
    Still cannot scan!!! Still get Error Message on Printer Panel when pressing scan button: "Check Connection"
    Downloaded and installed BRAdmin Professional, and it detects my MFC-440CN without any difficulty!
    What to do!?????!!!!
    Problem Solver:
  • 7 Answers
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Posted on Aug 27, 2009
    Sergeant:
    Novelist:
  • 198 Answers
Check whether the physical connection between the printer and your network is still active. If it is connected to port 1 of your router/switch check the lights on the router/switch if #1 is on. Otherwise, try a different port or use another LAN cable.
Check also the port where your computer is connected to. Make sure the lights are ON on the port where the PC is connected to.
If all the lights are good, check Brother BRAdmin Professional Network Management software if it still detects your printer.
Posted on Jun 25, 2009
  • Niqui Itliong
    Niqui Itliong Jun 25, 2009
    According to user manual, firewall may block scanning features on your network. please see below:
    (For Windows® users only) A Firewall setting on your PC may be rejecting the
    necessary network connection. Follow the instructions below to configure the
    Firewall. If you are using a personal Firewall software, see the User’s Guide for
    your software or contact the software manufacturer.
    1 Click the Start button, Control Panel and then Windows Firewall. Make sure
    that Windows Firewall on the General tab is set to On.
    2 Click Advanced tab and Settings button in Network Connection Settings.
    3 Click Add button, and in the "Description of service" field, enter any name. In
    the "Name or IP Address" field enter "localhost". In the internal and external
    port numbers fields enter "54925" for network scanning. Choose UDP and
    click OK. Repeat this step adding Port 54926 for network PC-FAX receiving
    and Port 137 for both network scanning and network PC-FAX receiving.
    4 Make sure the new settings are added and the box is checked, and then click
    OK.
  • 244 Answers
Looks like you lost connection.
Can be a lose cable. Check the phisycal connections.
But sometimes the IP that the printer uses may conflict with a computer or laptop from the same LAN.
That causes an error, and no transmition is done.
Double check the IPs in your LAN, and make sure that each equipment has its own.
It should work.
Please don't forget to rate this answer if its helpful
Brother MFC-440CN printer will not see new cartridge
Your print-heads, which take the ink, and spray it onto the paper, have become "clogged". Run a "print-head-cleaning-cycle" to try to unclog those jets.
Nov 26, 2010 | Brother MFC-440CN InkJet Printer
Networking
It isn't a network printer since it only has a USB interface (no LAN port)
http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/Brochure_MFC240C.pdf
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
http://www.amazon.com/Brother-MFC-7840W-Multifunction-Wireless-Interfaces/dp/B0016ZQ566/ref=dp_cp_ob_e_title_1
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Help
I say you throw it in the trash
Sep 23, 2008 | Brother MultiFunction Center MFC-440CN...
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
MFC-440CN: Prints but does not scan
Go to system/computer control panel, select "scanners and cameras". you should see your brother system in there (if u were able to print to it but not scan). Right click on it, select properties, and select "Network Properties" Tab. Choose select "specify your machine by address" rather by "by name". Most home/home office users dont have a local domain server at home, so even though your printer was named, it cannot be located by tcp-ip using the name, but rather by ipaddress. This solves the issue.
Feb 02, 2008 | Brother MultiFunction Center MFC-440CN...
Brother mfc-440cn
by uesing a special software.
The mfc cant print any mirrow images by itself.
But why do you need to print a mirrow? as far as I remember is the print straight right thru. The foil has to be turned onto the shirt before you run the iron?!!!
Jan 29, 2008 | Brother MultiFunction Center MFC-440CN...
Not working
Give it back to a service dealer. Its a guarantee job!
Nov 10, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
2,076 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
