SOURCE: When trying to connect a
Hi, I will need a little more detail about the issue before I can help you. Detail like which device are you trying to connect to, is this on network or local, how do you connect to device such by ip address or other means, make and model detail might help. Thanks
SOURCE: my friend gave me a
The most common defaults are the following = ""
admin/admin
admin/
/admin
You can also Google " default login"
Comment back with the model number or at least brand of router and I will help you find the default login
SOURCE: can,t get the activation code from pandora to work
It's been a while since I had to do this. Typically this error is a result of an error in the entry of the code when read from the screen. Make sure that you are not confusing 0 and O, 1 and l, 6 and G, etc. While similar in appearance - as you know they are not the same. Try with several variations - or better yet - have someone else try - sometimes a second pair of eyes makes all the difference!
