Question about Panasonic PT L735U Multimedia Projector
PT-L735 U projectors. Green screen and stretched
I have two PT-L735 U projectors. For the longet time, one of the projectors has a green hue to it even when I shutter the screen.
Recently my second screen started displaying a stretched picture (only in horizontal direction). The VGA input goes through the first projector and is sent to the second projector. I tried to adjust the projector and verified the screen was not zoomed. The sc
    Champion:
  • 205 Answers
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Posted on Jul 07, 2009
Hi , i have a panasonic PT-L735 U projector and i have a lamp problem ! when turning it on i have a red led of lamp on! and i thought at first that I must change the lamp is what I did but I still have this problem, does anyone has a solution for me? thank you in advance
Posted on Dec 23, 2009
    Problem Solver:
  • 6 Answers
Please check the image selected which apect ratio, also each and every projector connect directly and check.
Regards,
Prakasam
Posted on Jul 08, 2009
What does it mean when the projector goes on and off again
please check 200w lamp and 220w lamp is it same looking or not? You could send me picture if have. the problem is either lamp or ballast.thanks
If you have any question, do not hesitate to contact me.Mobile: 86-0-15915755963Web:http://www.yylamp.com http://www.yylamps.en.alibaba.comMSN: mickeywoo20@hotmail.com skype:mickeywoo1988Mickey Woo
Jan 15, 2013 | Panasonic Replacement lamp for PT-L735;...
I have a Panasonic PT-D5500U. We replaced the lamp, and then shortly thereafter, whenever we turn on the projector the power lamp goes from green and shuts off and blinks red three times continuously. ...
the problem is a known "bug" by the manufacture, which is due to low temperature issue that's detected by the processor of the projector. it will require a firmware upgrade. i'd recommend getting in contact w/ their tech support.
http://www.panasonic.com/business/projectors/ss_techsupport.asp
Jun 03, 2011 | Panasonic PT-D5600U DLP Projector
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
Green color on screen
Take out the up cover of the projector. Make sure all the screws are tight. Actually take out the main board and replace it again... That should do it. Otherwise there is a problem at your main board.
Feb 28, 2010 | Toshiba TLP-XC2500AU Projector
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Sony Office Equipment & Supplies
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
Panasonic PT L735U Multimedia Projector Logo
647 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
