I wiped my hard drive and need to boot from a cd but I forgot my bios password
You can remove/Disconnect the BIOS battery at the mother board. Also, you can clear and reset BIOS/CMOS setting at jumper points on mother board
Thats why they tell you not to save the information on a file on your hard drive. You should have it written down. I bet you won't make that mistake again!
i have used this software and no that it works although
you might have to get a computer with an internet connection to download and
burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains
software that allows you to repair, restore, or diagnose almost any computer
problem also has a bios reset tool which can remove your password and bios
password
you will have to burn it to
a disk as an ISO then you will have to
boot from the disc
During the boot process you will see on the
screen to press a certain key to enter setup Press and hold that key during the
boot up process to enter BIOS the scroll down to advanced bios features press
enter change your first boot device to cd press escape then press f10 to save
to cmos to restart (note after you have removed your password you will have
change first boot back to your hard drive)
Hope this helps
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
hope this helps
if you mean that you cant login to your computer because you forgot your password
hope this helps
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
hope this helps
