Question about Logitech Harmony 880 LCD Remote Control
My daughter spilled water on the remote and now I have an LCD module failure appear on the screen during testing, then the screen goes blank. Where can I send it for repairs?
Unfortunatly, Logitech does not provide repairs for Harmony products.
Posted on Mar 05, 2010
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
Canon Rebel EOS T3 - camera has power but there is no LCD display whatsoever.
Has the camera been dropped or had a liquid spilled on it? Sound like a circuit failure. However, if it has been dropped it may indicate that one of the flexes has come out or the little flipper on the flex connector has popped up and the connector is not working.
Apr 28, 2013 | Canon Eos Cameras
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
My daughter spilled milk on my cpmputer screen
no, the damage is irreversible. You can have the LCD controller board change out which will resolve the pixelation. However, the cost of doing that outweight the value of the monitor.
Enjoy the power of a PC
Mar 15, 2010 | HP Computers & Internet
Blank screen on logitech harmony 520 remote
If the firmware didnt help, then it is a hardware issue. You probably got water in the battery compartment or something.
Anyway you should call Logitech support for a warranty claim. Or, you can do it by taking a look at the following link:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12657
Hope I was able to help!
Jan 26, 2010 | Logitech Harmony 520 LCD Remote Control
Lcd off
check you bluetooth module in left rear cargo area access panel.check connectors for bluish corrosion,also look for signs of dried water spots,possible water ingress onto entertainment modules
Feb 23, 2009 | 2003 Land Rover Range Rover
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
The PSA diagnostics sequence begins.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
Note:
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
Press <N> or wait approximately 30 seconds to fail the color bar test.
Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
Note:
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
IF AN ERROR IS INDICATED, PLEASE CALL DELL SO YOU CAN SEND SYSTEM TO SERVICE DEPOT FOR REPAIR (WE'VE JUST TRIED TO ISOLATE ISSUE TO SEE IF ERROR IS CAUSED BY HARDWARE OR SOFTWARE, OR JUST SOME CONFIGURATIONS)
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
Blank screens on ds
ok um with the user manual you should have a number to ring nintendo would happely help you i wouldnt attempt opening it as this would result on your warrenty voided or go to a shop called mob chip,leading edge games,leading edge video but these guys ask for money nintendo dont just ring them
Jan 01, 2008 | Nintendo DS Console
Blank LCD screen
no screen display
Dec 01, 2007 | Samsung Video Cameras
Logitech Harmony 880 LCD Remote Control Logo
718 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
