I want to change my A/C to R134a. Do I need to do
I want to change my A/C to R134a. Do I need to do anything or replace any of the original equipment?
  • twostreams Jul 12, 2009
    1984 S10 Chevy Blazer 2wd. Stock equipment.
  • Jason vangel May 11, 2010
    what type of a/c is this
  • 92 Answers
R-134a will not work in you a/c,pressures are different!You Will Contaminate and ruin if you try!
Posted on Jun 25, 2009
R134a refrigerant
There is a very good chance your ac system was originally charged with R12 freon. If it was, someone will need to convert it to R134. That may require changing the receiver drier and some gaskets along with the adapter fittings for freon gauges.
Jul 01, 2013 | 1993 Land Rover Range Rover County
What freon goes in air condition?
This car originally contained R12, if you can find it you can use it. The other option if this has not already happened is you can convert the system from R12 to R134a, which is readily available, all auto part stores carry these kits. R12 AC fitting are threaded and R134a systems have slip on quick connect fittings.
Mar 03, 2012 | 1986 Chrysler New Yorker
What type of refrig. does the AC use in a 92 dodge caravan
Unless the labels are missing from the car, it will state which type of refrigerant is used. Could be either R12 or R134a. If originally R12, it could have been replaced by R134a with an upgrade kit. The easiest way to tell if the labels are missing, is to look at the valves on the AC system. If they are Schrader valves (same as used on tires), then it is the older R12. If the caps are Red (high pressure side) and blue (low pressure side), then it is R134a. The sale of R12 to non-certified mechanics is illegal in all states as far as I am aware. R134a is available in most states and retro-fit kits are available in most states.
I have done the retro-fit on 2 vehicles with acceptable results. It is recommended to remove all the old R12 with a vacuum pump. Autozone (in my area anyway) rents these.
Good luck if you need and decide to retro-fit yourself.
Jul 04, 2011 | 1992 Dodge Caravan
Is there a kit to change out the old original freon from my 1986 f150 to the new one being used
unfortunately there is no kit that has been made up, as it was not going to be cost-effective to make them up. What is required to replace is the receiver/drier assembly, the compressor will have to be drained of the oil in it, and then new oil and R134a gas put in.........it normally has to be done by a licensed air-conditioning installer.
Aug 23, 2010 | 1986 Ford F150 SuperCab
Need a replacement compressor < 8 " high for older refrigerator
How can you have a R134a Compressor that is 32 years old. That gas was not even available then. What you are asking is impossible, unless you are asking can you change from possibly R12 to R143a. The answer is yes but it would probably be too costly. you see R12 ran with mineral oil whereas R134a runs with Polyolester oil. the system would have to be completely flushed out of old oil, and the expansion device ( capilliary tube ), would have to be changed and cut to the correct length to appropriate the correct displacement of gas.
Apr 17, 2010 | Matsushita DD73C14GAU6 1/4 HP R134...
How many pounds of freon does a 1993 Saturn SL2 hold?
The R12 spec on the Saturn Threw 93, capacity R-12 2.1 to 2.25 lbs.
On the 94 -98 S-series cars; per the Haynes A/C manual these systems should take 6.5 oz of Ester oil and 24 oz of r134a refrigerant.
The amount of refrigerant required is printed on a label in the engine area. I think its 1.5lbs or 24ozs or two 12oz (net wgt) cans if your system is the R134a.
Thank you for using fixya and just make sure that your have the right system in your Saturn, it's going to be R12 from 1993 and earlier and 1994 will be R134a. Note: at if your not the original owner, your system may have been converted to the R134a.
Here is a link for you that should help you.
http://www.saturnfans.com/forums/showthread.php?t=80107
Apr 16, 2010 | 1993 Saturn SL2
While car was idling, I heard a ''popping'' sound. Looked under hood, near the ac high pressure line there was a green leakage coming from the switch.The top had blown, possibly from the Tx heat.Ac now...
Regardless the bad switch needs to be replaced. Your mostly going to loose some R134a and you may need to have the system serviced, but replacing the switch your self can be done like changing a spark plug. Just make sure your fast so you don't loose that much R134a and keep your cost of the repair to a minimum. Good luck and hope this helps.
Jul 09, 2009 | 2003 Hyundai Accent
1984 S10 Blazer A/C is R12. I want to change this.
they have a kit it has all you need to change over usually at any auto parts store and yes you will have to change the seals and a few minor things
Jun 25, 2009 | Heating & Cooling
What type of freon is in a 1994 GMC Suburban
There should be a lable underhood.but probably had R-12,Best to go ahead and convert to R134A.Recommend replace reciever drier ,buy conversion fittings from parts house for 134A,remove compressor turn upside down and rotate clutch by hand to get as much oil out as you can,then pour in aprox 4 oz pag oil.Reinstall,change orfice tube the will need aprox 12 oz R134A to replace 16oz R-12.Buy R134A at walmart cheaper than all parts houses by at least $2.00 a can.Cgarge till low side preasure at aprox 40 to 45 psi and gigh side 200 to 250 psi.Should cool fine.
Jun 19, 2009 | 1993 Chevrolet Suburban
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
