My KX-TCA60 Headset no longer makes connection with my KX-TG7644 phone. It used to be fine when I plugged into the headset jack. Now it clicks the connection on and off, and often makes a shrill sound.
SOURCE: for use with a headset
LOOK AT THE FRONT LEFT SIDE OF PHONE. THERE YOU WOULD SEE A JACK THAT FITS HEADSET. I DONT KNOW IF THATS THE SIZE YOU REQUIRE. BUT IT SHOULD WORK!!
SOURCE: the headset on my panasonic cordless phone makes a
I have the same problem with 5 of my 6 handsets now :( I do not know how to fix it
SOURCE: I have a Plantronic headset. I have moved to
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
SOURCE: Panasonic KX-T7731 headset mode? Could someone
It's automatic. Press the SP Phone button.
My headset is a TCA-60 and it works in all systems on all Panasonic phones.
Carl
Testimonial: "thanks for the help!"
try using an old hand set to plug into the wall maybe it might be you might have to have the fone company check your line
