Question about Element Electronics FLX3711B 37 in. LCD TV
TV is on, but screen is black.
Green light says TV is on, but no screen is visible. Cannot turn it off or anything. Must unplug to reset before it will work again. Also, turns off and on very randomly. Sometimes will work fine for days, some days, it turns off and on every several minutes.
  • alnjaksnfan Jun 25, 2009
    No, remote doesn't do anything when the tv "freezes".
  • Steve Allison
    Steve Allison May 11, 2010
    Is there any response to your remote or when the TV is malfunctioning is the remote ineffective?
  • Element Elec... Master
  • 5,568 Answers
In your set, there is a section that receives the IR signal from your remote, then translates the pulses sent and initiates the action you chose. I think the failure is happening in this 2nd circuit which is now doing whatever it wants. This section may be located on the main board or could be part of the IR receiver board. The only thing you might try is this:
- Pull the AC plug and let the unit sit overnight. - Remove the back panel of the set. - Look for any cables connecting the different boards, carefully unplug these one at a time and then reconnect.
If you are lucky, it is only the failure of contacts in one of these interconnecting cables. If there is no change in the behavior of the set, then a component has gone intermittant and to locate and replace the faulty component, you are stuck with either a board exchange or replacement of it. You will have to contact the service company for that brand to get the cost involved with either a repair or replacement board.
Unfortunately, the sets we are now buying are not nearly as reliable and far more complex than the previous generation of CRT-type sets made in countries other than China.
Posted on Jun 25, 2009
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
Nov 16, 2017 | Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
FLASHING RED LIGHT
Same problem as my Sony. Unplugging for 36 hours solved my problem
Dec 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
Element Electronics FLX3711B 37 in. LCD TV Logo
179 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
