SOURCE: Paslode framing nailer intermittent firing
OK lets start from the top, gas full, but what is the expiration date, it is located on the bottom of the fuel cell and if out of date can cause a problem. Second when was the last time the tool was taken apart and completely cleaned and serviced with new orings and lube? Lastly look at the nails are they traveling thru the magazine freely? Let me know and I will try and help further
SOURCE: Need cleaning instructions for ITW Paslode Impulse
I would recommend you go to Paslode.com and under support there is a section for cleaning of these tools. I can tell you how to do it but it is indepth. What kind of cleaning solution do you have? You can't just use anything to clean them. Also the red light on means a failure. Does the fan work? Does it have fire and it also means that the battery is weak. They also have a good troubleshooting section on the site. Let me know if I can help further.
SOURCE: Paslode Impluse Finish Nailer, fan does not run.
make sure the new fuel cell top part is firmly pressed in to the fuel cell
SOURCE: paslode 350 nailer wont work , push to fire fan
Hi, Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them. heatman101
Sounds like a battery contact problem or a bad battery..
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
SOURCE: im 250 nailer wont fire new
Hi, heatman101
with them.
If
Paslode
-]0]0-
