Question about Remington Polesaw Wizard
I need a replacement chain for my PS1510A - part accessory 10cs
  • 4 more comments
  • jsheff123 Jun 25, 2009
    The part # is: 10SC ... go tohttp://www.masterparts.net/index.html
    Thanks from jsheff123 - problem SOLVED!
    Go to:http://www.masterparts.net/index.html
    The part # you want is: 10SC ___not___ 10cs, Pal. :=)
    Part # you want is: 10SC
    End of Problemo!
  • jsheff123 May 11, 2010
    Problem SOLVED! Thanks to FixYa.com - people HELPING people! I just hung around REDING POSTS and the Solution Came. Thanks, agn to All! jsheff123
  • 188 Answers
Master Parts has the 10SC in stock. You can contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jun 25, 2009
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
Can I use any bike chain to replace lost rear chain?
I 'm not an exprt on bikes but the chain depends on the gears. If gears are same, you can use the same chains. So, all you should check if chain fits gears.
Oct 03, 2015 | Schwinn 26" Meridian Adult Tricycle, Dark...
Fellowes HD-10Cs won't shred. Power gets to machine because it will manually reverse when reverse button held. Can't get the sensor lights to work. Tried overide switch for sensor light. Held in...
Unplug from mains electricity.
use a cotton bud dipped in rubbing alcohol to clean the sensor
light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Jan 31, 2014 | Fellowes HD-10Cs Shredder
Timing chain making noise after water pump replasement
Basically its said,that when water pump is replaced,its also advisable to replace timing chain.The timing chain is either worn out or while replacing water pump,the timing chain got misaligned.It has to be inspected.Most probably,it needs to be replaced.
Below is the master help link provided to go through belt routing diagram:---Timing belt,timing chain, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 27, 2012 | 2002 Dodge Stratus
My chain is skipping on hill climbs
Skipping chain is usually caused by either one or two tight links, or a worn chain.
This is assuming the derailuer is in good condition and not bent or damaged.
Chain and sprockets need to be replaced as a set as a new chain on old sprockets can also slip.
Turn the crank backwards slowly and you wiil see if there are tight links as it goes through the small tensioner wheels
Aug 27, 2011 | Shimano Dura Ace Di2 RD-7970
Chain wont stay on
Did you replace the chain with a new one ? If the chain is to big for the sprockets than you need to purchase a link remover from anywhere that sells accessory's for bikes.
Remove one link at a time untill the chain fits perfectly.
Post back if you have further info. Thank you for choosing Fixya!
Mar 21, 2009 | Mongoose Toys
Remington Polesaw Wizard Logo
103 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
