2004 Holden Astra Logo
Anne De Lutiis Posted on May 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear power windows not working from the rear but works from the front
Power windows are not working from the rear controls, but are working with the front controls. any suggestions
Dave
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on May 29, 2014
 Dave
Expert
Level 2:
New Friend:
Answers
114
Questions
Helped
23121
Points
216
Bad switch--check with a multi-meter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
1helpful
2answers
1997 Buick Park Ave, passenger side and rear windows stopped working.
You say the driver window works? wouldn't be a main fuse or fusible link then -driver door locks and window wouldn't work either. Each door has a module inside (computer) . The driver door has a circuit breaker power feed an a fuse DDM fuse 10amp located in rear junction block circuit breaker is located in under hood maxi fuse block. The circuit breaker also feeds battery voltage to the other door modules too. PDM - passenger door module fuse 10amp located in the instrument panel fuse box and the RDM - rear door module RDM fuse 10amp located in the rear fuse box - under the back seat.
Each power window is connected to a permanent magnet motor. The motor raises or lowers the glass when the door module applies voltage to the motor. The direction the motor turns depends on the polarity of the supply voltage provided by the associated door module. The 2 front doors have their own separate modules. The rear seat contains a single module, which controls both of the rear power windows.
A serial digital communications link, called the simple bus interface, is used for communications between door modules and the driver's door power window switches. The use of serial digital communications allows the use of a single wire to convey switching information between the power door lock switch and the driver's door module (DDM). The serial communication is also used in order to transmit switching information from the DDM to the other 2 door modules.
The door modules apply battery voltage of the correct polarity to the respective window motor when any local, or power door lock switch, UP switch is operated, driving the window up. Battery voltage is applied to the respective window motor in the opposite polarity when any local, or power window switch, DOWN switch is operated, driving the window down.
Driver Door Module (DDM)
The driver's door module (DDM) directly controls the driver's door window motor and the express down window feature. The DDM sends window UP/DOWN messages received from the power door lock switch to the passenger door module (PDM) and to the rear door module (RDM) over the simple bus interface (SBI) line. The DDM also contains a class 2 data link which communicates with the other vehicle system modules. The left front power door locks and the outside power mirror are also controlled through the DDM.
Passenger Door Module (PDM)
The passenger door module (PDM) controls the passenger's door window motor. The PDM controls the passenger's door window directly from the right front power window switch or from instructions over the simple bus interface (SBI). The right front power door locks and the outside power mirror are also controlled through this module.
Rear Door Module (RDM)
The rear door module (RDM) controls both of the rear door window motors. The RDM controls the rear windows directly from the rear door window switches or from instructions over the simple bus interface (SBI).
2answers
My front passenger window stopped working. We've checked the fuse, replaced the switch and the door lock button works but not the window. Could this be the motor?
After I verify both driver window control switch and the passenger wdo control switches don't cause the window to operate, I turn off engine and go on ACC Mode and listen for a relay clicking in the door or the BCM while you operate the switch. If you hear a click, then it's a bad wdo motor.
2answers
I got a 2003. Cadillac cts and none of the windows work. I have checked every fuse I can find none are labeled for widows. Anyone know where the fuses or relay is located?
The following components are used to control the power windows:
• Driver door module (DDM)
• Passenger front door module (PDM)
• LH rear door module (LRDM)
• RH rear door module (RRDM)
• Driver door switch assembly (DDSA)
• RH front power window switch
• LH rear power window switch
• RH rear power window switch
• LH front power window motor
• RH front power window motor
• LH rear power window motor
• RH rear power window motor
• Class 2 serial data link
• DR MOD PWR C/B 30 Amp circuit breaker
• DRIVER DR MOD 10 Amp fuse -- DDSA and DDM logic, DDM internal driver operation.
• PSGR DR MOD 10 Amp fuse -- PDM logic and internal driver operation.
• REAR DR MOD 15 Amp fuse -- LRDM and RRDM logic and internal driver operation
1helpful
2008 CTS drivers door switches don't work Just replaced battery All fuses are good
Did the switch work before replaced battery ? 2008 CTS ? Cadillac ? These switches are inputs to a control module , DDM - driver door module . a computer of sorts . A lot of thing's can go wrong with these systems , broken power or ground circuits inside the rubber boot from the body to the driver door . Communication problems between control modules etc... Plus the power windows don't use fuse's , has a circuit breaker for front windows - PWR/WNDW circuit breaker 25 amp located in the fuse box under the back seat , Fuse's are used for rear windows - two 15 amp fuse's LT/REAR an rear ,both are in the rear fuse box under back seat. These rear windows are controlled by the BCM - body control module .
The power windows system consists of the following components:
• Driver door module (DDM)--GMLAN device that receives and transmits messages and signals for window functionality. The DDM contains the driver door switch (DDS) which is integrated into the module. The DDS contains the driver, front passenger, RR and LR window and window lockout switches.
• Passenger front door module (PDM)--GMLAN device that receives and transmits messages and signals for window functionality. The PDM contains the front passenger door switch (PDS) which is integrated into the PDM. The PDS contains the front passenger window switch.
• Left rear power window switch--Provides switched voltage and ground window switch signals to the left rear window motor for left rear passenger window operation
• Right rear power window switch--Provides switched voltage and ground window switch signals to the right rear window motor for right passenger window operation
• Left front power window motor--Contains position sensors and a module that receives signals from the DDM and provides a status signal to the DDM
• Right front power window motor--Contains position sensors and a module that receives signals from the PDM and provides a status signal to the PDM
• Left rear power window motor--Contains position sensors and a module that receives signals from the left rear power window switch
• Right rear power window motor--Contains position sensors and a module that receives signals from the right rear power window switch
• DRIVER DR MOD fuse (15-amp)
• PDM fuse (15-amp)
• PWR WNDW Circuit Breaker (25-amp) -- front
• LT/REAR/WNDW fuse (15-amp) -- rear
• REAR/WNDW fuse (15-amp) -- rear
Power Window Operation
The driver and front passenger doors are equipped with power window motors that contains its own module. Each power window motor receives a hot at all times battery supply voltage and constant ground source. When the right front passenger window switch on the DDS is activated to the up or down position, the DDM will interpret the signal and send a GMLAN serial data message to the PDM. Upon receipt of the message, the PDM will send a signal to the front passenger window motor module on the GMLIN serial data circuit. The window motor module will then supply battery voltage and ground to the window motor to drive the window motor to the up or down position.
The DDM communicates via the GMLAN serial data circuit with the body control module (BCM) to control the rear window functions from the driver master window switch. The BCM is hard wired to each rear power window switch with circuits for window up, window down, and an enable circuit. The rear window switches contain internal logic that when supplied with voltage from the BCM over the enable circuit will driver the appropriate window in the direction commanded.
The rear power window switches are supplied with battery voltage from individual right and left WNDW fuses located in the rear fuse block. When a rear power window switch is activated to the DOWN position, voltage is applied to the motor down circuit and the motor up circuit serves as the path to ground. The window motor will drive in the downward direction until the switch is released or the window has fully opened. When the window switch is activated to the UP position, voltage is applied to the motor up circuit and the motor down circuit serves as the path to ground. Ground for the left rear power window switch is supplied at G200 and the right rear power window switch receives ground at G201.
The power locks work the same .
After replacing the driver door switch (DDS) or passenger door switch (PDS), perform the programing procedure.
If you don't know any of what i posted your best bet , have a qualified repair shop check it out .
I have a 2001 Saab 9-3 convertible that has a problem with both of the rear side windows not working and also main swithch that controls front and back not working for two rear side windows.Both front...
Bruce, ur best bet would be to replace the main control switch. change that switch and most likely all will be good. find urself a used main control (window) switch in the front or between front seats. buying used will be a hard find but still u will save money on that.
I hope this work out for u.
I have an 02 pontiac boneeville My power windows and my poer locks will not work the lights inside my car will not turn on and my radio will not shut off when my car is turned off and the key removed. it...
Do you know what electronic control modules are ?
Power Windows System Components
• Driver Door Module (DDM)
• Passenger Front Door Module (PDM)
• LH Rear Door Module (LRDM)
• RH Rear Door Module (RRDM)
• Driver Door Switch Assembly (DDSA)
• RH Front Power Window Switch
• LH Rear Power Window Switch
• RH Rear Power Window Switch
• LH Front Power Window Motor
• RH Front Power Window Motor
• LH Rear Power Window Motor
• RH Rear Power Window Motor
• PWR WDO 30 Amp Circuit Breaker
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door power window can be operated, either from a switch built into the driver door switch assembly (DDSA), or from a switch mounted locally on its associated door. The driver door power window can only be operated from the driver door window switch built into the driver door switch assembly (DDSA).
When the driver door module (DDM) receives a window switch request from the DDSA, the DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation to occur. If the status information is correct, the DDM, either supplies power and ground to its associated window motor, or, if the request is for one of the passenger windows, sends a command via the power door serial data circuit to the passenger door module (PDM, LRDM, or RRDM) controlling the window. The passenger door module (PDM, LRDM, or RRDM) controlling the window then supplies power and ground to its associated window motor to move the window as requested.
When one of the local window switches mounted on one of the passenger doors is operated, the associated door module examines the request and checks to see if there are any messages from the DDM prohibiting the movement. If conditions are correct, and no prohibitive messages have been received from the DDM, the associated door module then supplies power and ground to its associated window motor to move the window as requested.
Your best bet , take it to a qualified repair shop that has the diagnostic tools to diagnose this . Do you know what DTC'S - diagnostic trouble codes are ? DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522.
Hooking up a factory scan tool checking codes and seeing if the door modules communicate .
3answers
12helpful
4answers
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Top Holden Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Holden Expert? Answer questions, earn points and help others
