Question about Sony KP-65WS500 65" Rear Projection Television
Double image ( Ghost image )on Sony KP-65WS500
I get double image on my Sony KP-65WS500. Flash focus doesn't work. How do I fix it ?
  • 668 Answers
Replacing the Convergence ICs should fix the problem. They are located on the Deflection board. Sony has used a couple of different ones over the years I think they are STK-392-120's but please do not hold me to it.
Hope this helps,
Skyassoc
Posted on Jun 25, 2009
Out of focus, double blurred image with pinks & greens
Out of focus, double blurred Problem with the Sony KP-51WS500 51 in. Rear Projection Television
Apr 21, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Double image, green and yellow ghosts, blurred image - Flash Focus does nto do anything, convergence adjustment does not work at all
That means convergence out ICs are not working, requires replacement.
If you want to replace convergence out ICs, let me know to provide you technical info.
Thanks.
Aug 17, 2009 | Sony KP-51WS510 51" Rear Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Double images
You need to replace both convergence ICs they are STK392-560 you can get replacement ICs at the following link and they provide free installation instructions with pictures so you can install them yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | Sony KP-65WS500 65" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Double images
Needs convergence circuit repair----Replace STK IC's and
check for burnt resistors or open fuses.Then touch flash focus..
Let me know............T.
Nov 01, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
610 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
