Question about Canon BubbleJet i560 InkJet Printer
Constant cleaning problem
My Cannon i560 is cleaning way too often. It cleans for about 40-50 seconds befor it prints and again after each print. Should i just leave it turned off or is there a better solution? I haven't used it that much in the couple of years I've had it but it didn't have this problem befor.
  • 106 Answers
Please go to Printers & Faxes locate your printer and right click, then go to properties>Maintenace. You will find the cleaning setting where you can set it to less cleaning.
Posted on Nov 08, 2007
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
Printer, Canon i560, has not been used for ages.
first of all it require servicing like cleaning of steel rod inside in the printer on which print heads move ,that you can do with lubricant oil and second thing you need to change the cartridges because they may be already dry because you not used for very long time. In short if you can do this entire thing well otherwise I advised you to show it service center.
Nov 25, 2009 | Canon BubbleJet i560 InkJet Printer
I have a Cannon i560 printer. The printer will
Check to make sure you're not adjusting it to fit the page. This can shrink the entire doc..
Look in the print dialog window when you select print from the file menu.
There should be options to select or deselect before clicking to print.
You may also check your page setup to make sure you are printing at 100%.
Let me know if you solve this one...
Oct 30, 2009 | Office Equipment & Supplies
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
I have a Cannon i560 and I am getting 5 blinking yellow light the green and then it repeats. All indications is that I need a new print head. I want to be sure this is it before buying the print head.
5 blinking yellow or 7 blinking yellow in canon printers means you need to replace the ink cartridge or head with a new one. If you want to be sure, then take the print head and see if there is any burned area or damaged near the head and sometimes it is very small like a needle puncture. if there is, you need to buy a new one. if not, try to clean the head with 96% alcohol, let them dry before you try to put it back.
Sep 14, 2009 | Canon BubbleJet i560 InkJet Printer
HP psc 1310 series printer Will NOT work.
Here's the link to the Cannon Support page for the drivers for your i560:
Click this link for assistance with your HP 1310 printer:
Mar 27, 2009 | Canon BubbleJet i560 InkJet Printer
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
New computer
you can get a canon driver here
go to print drivers
canon icon
enter model and operating system
Mar 19, 2008 | Cannon i70 Printer
Canon BubbleJet i560 InkJet Printer Logo
41 people viewed this question
old marine
old marine
