Question about Digital Video Systems Plenio VXA-3000 GPS Receiver
I need gps program for plenio vxa3000 i dont have
I need gps program for plenio vxa3000 i dont have the backup disk or origanal sd card what can i do?
  • 29 Answers
Whats Is The Units Serial#?
Posted on Jan 31, 2010
MobileNavigator
Need Plenio VXA3000 OEM Files/Maps?
Jeffreydrescher@Bellsouth.net For Login & Password
Files Located @ MS SkyDrive/NAV-360 No Threats Found
Plenio Serial Number Required
Feb 02, 2014 | Digital Video Systems Plenio VXA-3000 GPS...
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
Navigator is not reading my sd cards
Pg-5 Owners Manual List Recommended SD Card's That Are Proven To
Work, I used Transcend 80X SD 1GB & PNY Optima SD 2GB In My
Plenio VXA-3000. Need Manual, jeffreydrescher@Bellsouth.net
Not All Card's Will Work If You Need To Replace a Bad One
Some CF Cards Are Not Designed For Embedded Purposes, ie;
Installing Win-98- MS-7 (Fixed-Mode), They Can Be Used For Camera's,ect.
Not Sure Which -Mode- (Fixed vs UnFixed) Are Used For The Plenio,
But This Is Why All CF Cards Are Not The Same and Might Only Work
In Certain Application's.
Oct 08, 2011 | Digital Video Systems Plenio VXA-3000 GPS...
I need a sd card for my vxa-3000
You seem to be saying you have a card but you lost it Which is it?
If you have the original card make sure there is data on it that is valid. If you lost the card ( and I don't know how you could do that!) then you will have to buy a new licenced piece of software. The licence is tied to the SD card Pirated maps will not work.
Jul 22, 2009 | Digital Video Systems Plenio VXA-3000 GPS...
Plenio VXA-3000 GPS Navigation System Memory Card Reader
Do Internet Search Google/yahoo for a
SD memory chip Card Reader, will most likely support
other Memory Chips Used Today, connects to your PC via
USB Port. Aprox $25.us
Need Tech Support?
Dan Kim DVS Sales {OEM-Plenio-Rep}
408 970-3388
www.dvssales.com
Dec 28, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
No navigation on plenio vxa 3000
www.dvssale.com
Call Dan Kim 408-970-3387, DVS-Tech Santa Clara, CA
Email dankim@dvs.co.kr
Email kimus@dvs.co.kr
1st try reseating SD-Chip and that SD Icon Turns Blue, [It See's SD-Chip]
Do You Have OEM Plenio CD?
I Own One Myself, Just Upgraded to 2GB SD Chip, Reloaded Software w/Map Ugrade
Still Working Fine
Dec 12, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Reset
Try Removing SD Memory Chip From Unit, Remember What Side
of SD-Chip Faces Forward, Slide The SD-Chip, White Tab To
Unlock.
If This Fails
www.dvssale.com
Still Working Fine
Oct 03, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
SD card reader seems to be dead
Need Tech Support?
408 970-3388
www.dvssales.com
JEFFREYDRESCHER@bELLSOUTH.NET
Plenio VXA-3000 Owner
Forget The Nail, Plenio Is Not Detecting SD Memory Chip, Sound's Like It Is Not Fully Seated
in Reader On Plenio, Call Kim
Sep 08, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Plenio GPS 3000
Plenio Is Litttle Picky On What SD-Chip To Use, I Just Upgraded Mine To 2GB SD-Memory
Chip Purchased From Walmart, Mgr Name Is a PNY, Black and Gold Display Case, also
Say's OPTIMA SD Ultra High Speed, Mgr Bar Code# P-SD2GB-FS [On Back Of Display Case]
During My Upgrading to 2GB Chip, Using Plenio-OEM CD," Navigation Map Data Base" DVD-ROM
Version 4.0. Had same problem,
Using Plenio Folder on PC " C:/Plenio/V-Up Pro 3000/VUPro3000.exe, checked box, SYSTEM UPGRADE, Selected SD Memory Drive, [My PC Was F:/], then software should detect SD-Chip
and Display Free memory Size, If So, Then Select Next, Should Take Aprox 20 minutes to Complete
Installing Plenio Software From Your PC to SD Memory Chip.
I'am Sure That IS How It Went For You, Mine Did Not Work For Navigation Either, Everything Else Was OK.
Take Your 1GB Chip And Copy To Your Hard Drive, ie; C:/Plenio/OEM_Plenio_1GB_SD
[Good To Always Have A OEM Backup]
From Windows Explorer Locate This Folder Name On The 1GB SD Chip Directory: MobileNavigator.
In This Folder, Locate File: Device.cfg & MobileNavigator.exe & rdat [No File Extension Displayed]
1] Copy These File's To Same Folder On Your 2GB SD Chip.
Your System Now Has Knowen Operating System Installed and should work like before,
might want to recheck your personal setting's.
I also noted using Plenio Software, I could not Check-Box "OS Upgrade" I think this is why
It Did Not Work. Still have to ask Plenio-Tech About This.
www.dvssale.com
Contact Dan Kim [USA] 408-970-3388 office
I also Noted CD I have Installed Larger Map File Size Than The Preloaded 1GB-Chip Has On it.
located in the "Cities" Folder, file: iusa_110mb_en_standard_cg.cdt 114,232KB
CD Ver 4.01 Installed this File; iusa_180mb_en_cg.cdt 184,145KB
Also Came Up Somewhere With Plenio a: iusa_50mb_en_cg.cdt 48,258KB
I'am Not a Plenio Tech-Rep Just A VXA-3000 Owner
Also Installed 103 MP3's and 20 .bmp Pics/Slideshow, had 480KB Free Memory Left
jeffreyDrescher@Bellsouth.net
Aug 02, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Digital Video Systems Plenio VXA-3000 GPS Receiver Logo
533 people viewed this question
Top Digital Video Systems GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Digital Video Systems GPS Expert? Answer questions, earn points and help others
