Question about Compaq NX6110 TFT XGA Notebook
Compaq nx6110 power issue
I get error message on power up:
the procedure entry point?WriteConfig@ACAdapterConfig@@AEHXZ could not b located in the dynamic link library athcfgll.dll or athcfg11.dll.
Re: Compaq nx6110 power issue
Where do I get the following application: athcfgll.dll???
Posted on Dec 28, 2007
  • 117 Answers
Re: Compaq nx6110 power issue - Compaq NX6110 TFT XGA Notebook PC Laptops
I think this is operating system problem
Posted on Nov 05, 2007
0 characters
3 Points
Error message: procedure entry point PowerReadACValue could not
tvagente.exe is used to use computer as a TV. If you do not use it, you may want disable it. It uses excessive system and memory resources If you are not using the TV application, you should remove it to improve your overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
Mar 06, 2010 | HP Pavilion dv9000z Notebook
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Unknown hp power-on password
Did you do all these steps in order?
1) Remove the computer power pack battery. Remove the keyboard.
2) Remove the RTC battery. Wait 5 minutes. (I would wait longer, maybe 15 minutes.)
3) Reinstall the RTC battery. Reinstall the keyboard.
4) Plug the AC power into the computer. (DO NOT INSTALL THE POWER PACK BATTERY AT THIS POINT)
5) Turn on the computer.
This should reset the password and also all CMOS settings.
Jan 26, 2009 | HP Compaq nx6110 Notebook
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Power Surge error message
Jan 02, 2008 | Compaq NX6110 TFT XGA Notebook
Error messages
Try removing the jumper from the harddrive, then restart
Take the jumper off restart shut down and then put it back on again
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Dec 01, 2007 | PC Laptops
Hp compaq nx6110 wireless problem
Nope - battery is not the problem. Most likely problem is that the wireless radio is using POWER SAVE MODE which shuts it down (or lowers the output power) in times of low network activity to save power. Check in CONTROL PANEL -> SYSTEM -> DEVICES -> NETWORK ADAPTERS -> (wireless card name) - PROPERTIES and then look for an entry in CONFIGURATION and so forth called POWER SAVE and disable it. It might also be controlled through a third party software program running on your machine (something like "Intel wireless configuration" that may also be running in your system tray) - investigate that and look for an entry that says "allow the wireless card to shut down to save power".
Good luck.
Nov 16, 2007 | Compaq NX6110 TFT XGA Notebook
Problem with monitor
Hi Gabzie,
Don't worry regarding that the issue regarding the display could be probably you try changing the brightness when you  are plugged with  you power  supply and regarding the non system disk error may at that point of time the system has taken both the hard disk and dvd drive as master that is the reason you have got this message if this repeats then please provide me the serial no. and product no of the notebook and where do you live so that i'll guide you.
Oct 17, 2007 | HP Compaq nx6110 Notebook
PC Laptops Logo
196 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
