Question about Sony Handycam DCR-TRV130 Digital Camcorder
I can record audo but no video..shutter doesn't seem to open
Acts like the shutter is not opening because I can record sound but no video even thought the tape within the cam recorder is turning as though it was recording.. When I play back what I just recorded I can get audio but no video
  • 508 Answers
Try cleaning unit with rubbing alcohol and qtip the head and let throughly dry before use!!!Good Luck to You!!!
Posted on Jun 25, 2009
Shutter will open but not close
Sounds like the camera is not getting battery current, since that is how it will act without batteries. Does the meter needle respond to changing light when switched on? If not, check battery polarity -- the + end touches the strip at the bottom of the battery compartment, the - end touches the battery cap. If that all checks out right, one of the wires connecting the battery compartment to the innards may be corroded or loose.
Sep 01, 2013 | Nikon FE 35mm SLR Camera
Hi! I've just bought a Lomo LC-A on ebay, and it seems that the shutter doesn't work properly. It opens and closes, it doesn't get stuck, but there's only one click, even when I put it in...
It's got ONE speed - 1/100. It's designed to use ISO100 speed, outdoors in daylight, or with flash, using sunny 16 exposre. These are incredibly basic machines similar to Holgas and Diana's. 1 or 2 f/stop choices, 1 shutter speed, maybe a flash connection.
Jul 07, 2011 | Lomo LC-A 35mm SLR Camera
When I play back a recording on my camera, it is perfectly fine. When I put it on my computer, the video and sound is out of sync. The video is also in slow motion. Why?
Sounds like your computer is having trouble decoding the video. You might try a newer video playback program, such as VLC (http://www.videolan.org).
Sep 16, 2010 | Nikon Coolpix S4000 Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
Sony Handicam
dear kwilsey,
just turn on your camera and look at the front side of camera.i.e just note tat your lens shutter is opened. if lens shutter is opened then prob is with your ccd devices. Contact the nearest authorised service centers.
Sep 05, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Shutter opened but won't close
Switching off the camera from the main ON/OFF swit5ch should close the shutter. If it doesn;t, try removing the battery or the CF card. It is possible to manually increase the shutter speed even in bright sunny conditions.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 09, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Oct 03, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Handycam DCR-TRV130 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
