Question about MyMusix PD-6070 MP3 Player
Won't stay connected or transfer files
This POS keeps claiming to be disconnected from the USB port can't get it to format or transfer files. IT also claims to be full when there is nothing on it
Install media player 11and do a firmware update on the device
good as new
Posted on Jun 25, 2009
How I can repair a USB that ejects itself when transferring files?
This may be problem with defective USB port or Suitable Drivers not loaded in your PC. Use Terra Copy Software and try once
Dec 23, 2016 | Computers & Internet
Cannot transfer photos from phone via the usb cable
There are issue with usb port, virus and perfomance.
1. Try using other port. If you using front panel(pc) port, then use back panel usb port.
2. If problem, try change your cable connection(cable problem)
3.Try wait around one minute to get your pc/laptop properly connectd to your camera.
Issues with memory card problem.
1.try tansfer file using memory card reader
2. If okay, format back memory card and checking disk. Before format, backup all picture and video or any file to pc/laptop that you use.
good luck..
May 28, 2011 | Cameras
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
How to format memory stick
If you want to format your Memory Stick Duo memory card while it is inserted in the Sony Ericsson phone, you may get an "Memory or Application In Use" error.
The correct way to format the memory card is to first change the USB port mode on the phone to File Transfer mode while it is disconnected from the Windows PC. Then connect the phone to Windows PC. It will be visible as a Disk Drive in Windows Explorer. Right Click and format it.
Nov 27, 2010 | Sony Ericsson K530i Cellular Phone
Connects and Disconnects often
I think Gryph that you may want to try another usb port, but if that dosn't work then im not sure
Mar 14, 2008 | Creative Labs Zen Digital Media Player
Help!!!
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Jan 21, 2008 | Creative Labs MuVo Micro N200 MP3 Player
Fill system error in muvo v 200 usb
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=702,E=0000000000295070241,K=561,Sxi=1,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(4656),Kb=ww_english_add
Dec 03, 2007 | Creative Labs MuVo V200 MP3 Player
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
MyMusix PD-6070 MP3 Player Logo
104 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
