Question about Amana AP073M 20" Portable Air Conditioner w/ 7,000 BTU, 115 Volts & 8 Hour Shut Off Timer
Air conditioner timer
How do you use timer option?
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Air conditioner manuals
Call a technician, module should be replaced.
Feb 01, 2014 | Heating & Cooling
Setting timer on window unit to turn on and off
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
Oct 03, 2012 | Frigidaire FAS257S2A WallWindow Air...
How to clear timer mode on air conditioner
Very simple. Remove batteries from remote and after sometimes replace batteries and use the remote.
One more method, press timer button and then press < or > till it comes to 00.00. And then press set button.
Another method, press timer on and then press cancel button. Hope, helpful?
Feb 11, 2011 | Fujitsu 36CS Air Conditioner
Hi. my room air conditioner model: hwr12xc8 timer is not working
Switch on a/c and then set timer. You will get beep sound. If no sound communication error between unit and remote.Replace remote.
Jan 04, 2011 | Haier HWR08XC7 Air Conditioner
Searching for manual for my simplicity portable air conditioner
Yes can you please provide the make and model # so We may help more.
Jun 13, 2010 | Heating & Cooling
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Goldstar/air/window unit/runs for awhile and turns off
Does it have energy saver option? Check if you have timer option. If your units runs and then turns off without restarting by itself and you don't have those options call manufacturer or take it back and get your money back.
Jul 20, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
