Question about Sharp SD-AT1000H System
Turns off I was listening muzic out loud and then kid droped subwoofer somehow and wires touched and it turn off since then i have tried everything, it just turns on and after 2seconds off...thank you
    Brigadier General:
  • 6,966 Answers
Based on your post description, a short was introduced to the output of your system (wires touched). Since you were playing at a high level and the touching wires represents a 0 ohms load, there is a strong possibility that the power amplifier burned (too low a load at too high an output). The burnt component then represents a failure. When you try and power on the unit, it will go to its built-in diagnostics/initialization stage where it will sense the fault and thereafter go to auto-protect (shutdown).
Corrective measure would involve opening the unit and performing diagnosis of the circuitry and components check. Since these call for familiarity with electronics, use of a DVM and a soldering iron, perhaps your best course of action would be to seek the services of a qualified audio technician. Should you venture a do-it-yourself, you would need to concentrate on the audio amp, specifically the finals or outputs which could be a large power IC or a MOSFET pair. Determining which is at fault would simply be removing suspected component and verify that the unit will power on albeit any sound output. Of course the usual precautionary safety measures apply when working with live units.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 05, 2007
Vizio sound bar model vsb211
It might be clipping so just try turning it down. If you usually listen to it loud it might have blown though. The problem also might be your power supply if it cant keep up with the power needed for the speaker
Jul 28, 2013 | Vizio 2.1 Home Theater Soundbar with...
My friend just installed my subwoofers into my car. They are Dual 12 inch 1100 Watt speakers with a Pyle 1400 watt 2 channel amp. He installed his own speakers in his car so i trusted him with mine. He...
your getting fead back. check the ground on the amp it needs to be bare metal and tight also check the rcas they need to be tight and if its only hapening wile u play the ipod try switching wires from the i pod it hapens all the time with aux cables they break easy.
Sep 28, 2010 | Dual Car Audio & Video
95 Lincoln Town Car Speaker Issues.
Turn on radio on half and get in the back seat and listen for distortion and if that dont work turn off the key unplug one speaker at a timeuntil you find it the wire are in the trunck connected to the speaker.Listen then not exceeding the power on the speaker and you wont need to turn it up that loud you will notice whats blown quickly.
Jan 13, 2010 | 1995 Lincoln Town Car
Earphone plug is not working
do your speakers have their own volume knob? sounds like its turned way down,master volume in control panel under audio devices,also volume controll in the sound card software ,nvidia,realtek,maestro,ect. whitch ever one you have,if they are all turned up ,try turning it up useing your hotkeys on your keyboard,if none of that works,uninstall all of your audio drivers,and reinstall them from the support web site at,the wires that go to that headphone jack inside are very small,doesnt take much to damage them,droping it a couple times is enough,reinstalling the software is the best chance,if that doesnt do anything ,you will have to go inside,if this only happens when your using the optical drive then disregard everything i just said,and replace it.make sure its locked in securely
Sep 02, 2009 | HP Pavilion DV2910US Laptop
Won't stay on, turns off by itself
With a 1.5 Volt Dry Cell (AA Size), connect two pices of wire with the Cell. Momentarily touch the wires with speaker several times. It should produce click sound when wires are touched. If not then speakers are defective and need repair. Do not touch the wires for more than a second, touching the wires for a long time may damage the speakers.
Jul 06, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Surround System Subwoofer Intermitent
have u checked for loosened pieces in the subwoofer case ?
Most probably is the wire that connect on to the speakers membrane, that broke off from the glue it holds it ...
also check the filters ... (the capacitors , see if they are inflated,burned, or blackened, and if so change them ..)
Jan 24, 2008 | Emerson AV101 System
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
Sharp SD-AT1000H System Logo
281 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
