Related Tags:
This problem should be removed because:
Problem with Westinghouse SK-32H540S 32 in. LCD TV
TV goes black
My TV will turn on and show the picture for 5 seconds and then go black as the sound continues. I have unplugged the TV and reset my dishnetwork receiver.
Solutions (2)
Best Solution
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
The power and inverter boards are combined in this model. If you inspect the three transformers that power the lamps you will most likely see that one or more is deformed (looks like it is slightly melted). You will also notice that the board under the transformer is discolored due to heat. This board is also known for bad solder connections. The actual repair would be to replace the transformer (T1, T2, or T3) but as of writing this I have not found that part available without having to buy the complete board.
picture is really snowy in the bedroom and we have
picture is really snowy in the bedroom and we have another lg tv in the family room and it has a great picture on it they are both hooked up...
I have a Sova monitor that I'm trying to hook...
I have a Sova monitor that I'm trying to hook up to DishNetwork. I get sound but no picture
lg plasma screen will not
lg plasma screen will not zoom. There are black bars on the left and right side of the picture. Input is fron Dish Network, does this...
I have a picture but no sound sound on HDM2.I have
I have a picture but no sound sound on HDM2.I have dishnetwork. There is a very minimal amount of sound for about 5 miniutes then it goes...
Add Your Solution
invalid format ps3 to westinghouse sk-32h240s tv
I get invalid format from HDMI and AV inputs when trying to play ps3
my hair is coming out when i wash and brush it...
i used box color from a store twice in 4 months what can i do to stop it or make my hair healthy again
Screen looks like color bar code but will...
Tv will work correctly for 10 minutes sometime hour.
hi vidal i was reading you solution to the...
Im comfortable with soldering boards and just needing some guidance on what to look for specifically on this particular...
Fix-O-Meter
537
537 people viewed this problem
- 3 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Westinghouse Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
