Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in neutral any ideas? The carbs were cleaned at a dealer in the fall because it wouldn't idle
  • jdlhp Jun 28, 2009
    they are all the way open
  • jdlhp Jun 30, 2009
    Reply I found a plugged jet I think its called a pilot jet. Thats what they are called on a snowmobile. it was starving for fuel at high RPM on one carb the other 2 were working fine so it couldn't produce full horse power.  I will put it back together on Wednesday and let you know if it works.
All 3 carbs had A  clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks John
Posted on Jul 09, 2009
  • 5,687 Answers
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Posted on Jun 25, 2009
  • fordexpert Jun 29, 2009
    I see. Then the problem is not with getting enough air or throttle position. This means nothing in the linkage is blocked and you are getting all the travel you need right to the end. If you have a second tank have you tried them both? I am thinking you are left with two possibilities. The fuel area-clogged screens, weak pump, or lines sucking air. Or the spark area, spark advance is not advancing. When you move the throttles an electric part like a stator should move with the linkage and advance the spark. You would need someone to check the timing.
  • fordexpert Jun 30, 2009
    I would be interested to know if you fixed your problem. If you found debris it had to come from somewhere. It would still be good to inspect all the fuel screens.
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Aug 02, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
I have a merc 40 hp x 4 engine starts and runs fine but every 20 to 30 minutes it decides to just stop dead after a few minutes it runs fine again,
this is HP computer forum , not BOATS
but can answer ,
bad fuel!! all boat fuel goes bad, parked, so long, ALL DO.
too much oil in fuel (is it 2 stroke engine? no year given,so.,....)
carb, filthy, im cleaning my 40 hp now, in the garage, and wheel grease.. (fishing next,cat fish... hummm)
can be bad spark plugs. ever tune it up. with new ones?
water in fuel. rust in tank if tank is steel.
wrong fuel someone put in diesel
low compression (3 cylinders like mine?)
May 25, 2017 | HP Computers & Internet
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Stumbling on acceleration
You may be cruising down the wrong road with the exhaust idea but then you might be right. An exhaust restriction should also cause the engine to run hot. A faulty cat should also set some codes.
If the injectors are dirty, you may have a very lean fuel mix on one or more cylinders under acceleration, which would go away once you are not under load. And injector problems won't set any codes unless an injector stops working completely. Low fuel pressure could cause the same type of issue.
Dec 04, 2012 | Cars & Trucks
I have a 2004 60 hp yamaha 2 stroke outboard engine that doesn't start or run well. Once warm and in the water it will idle in nuetral and also in gear. It accelerates in neutral but will die or lack power...
Every sympton you are describing here can be attributed to fuel starvation due to blocked jets and or water in carbs, when your engine dies does it die with dry plugs, or wet oily ones?
Mar 25, 2011 | Sport & Outdoor - Others
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
3,012 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
