Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
Nikon 50mm 1.8 lens error message
HI, I own a Nikon D90 and have just purchased a Nikon 50mm 1.8 lens. This is my first lens i have used besides the ones that come with the kit. Ive noticed I get an error message and the camera wont work until I have rotated the dot to align on the 22. Is there anyway to make it work on the other numbers? If not what is the purpose of the ring turning the other numbers. I tried on all modes A,P S, M. Thanks heaps
  • 146 Answers
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Posted on Jul 03, 2009
What is best lens to photograph kids for headshots and 3/4 to full body shots with the nikon D90? the best lens for between $300-$500?
One of the best portrait lenses for the Nikon D90 is the Nikkor 50mm f/1.8 lens which can be found here: http://www.amazon.com/Nikon-50mm-Nikkor-Digital-Cameras/dp/B00005LEN4/ref=sr_1_1?ie=UTF8&qid=1298955171&sr=8-1. At low f-stops the lens blurs the background beautifully and will really make the pictures of the kids pop. An added plus is that it can take great photographs in low-light situations. It only costs $125 as well.
Jan 28, 2011 | Nikon DSLR D90 Digital Camera
I am trying to mount the AF f/1.8D 50mm lense on my Nikon D90- I do not here the click sound - when I turn on the camera, in the view finder I see F-- flashing all the time in any mode. Can you help me...
This particular lens is known to be a tight fit, especially when new. Most likely you just need to turn the lens a hair more and a little bit harder than you normally would in order to have it "click" home.
Dec 18, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Hi i purchased also Nikkor AF 50mm f/1.8D and i could'nt hear the click sound when i mounted it on my Nikon D90 cam, and return to my kit lens and it's doing very well. I did follow the advised you give...
You need to turn the aperture ring to its smallest aperture (f/22) and lock it using the little orange slide. Control the aperture from the camera, just as you do with the kit lens.
Nov 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I just purchased the Nikon AF f/1.8 85mm lens and it's giving me an error message on my D300, it wont let me change the apeture via lens ring,if the ring is locked I can adjust it with the controll wheel...
There doesn't seem to be a problem with the 85mm.
Nikon has made a lot of different 50mm f/1.8 lenses, so I won't say anything about them without knowing which particular type.
Dec 25, 2009 | Nikon 85mm F1.8 D-AF Lens
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
Jul 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Turn off focus assist beam on Nikon
Custom Setting Menu A, autofocus, setting A3 "Built-in AF-assist illuminator".
174 in my D90 manual.
"Choose whether the built-in AF-assist illuminator lights to assist the focus operation when lighting is poor"
Jul 06, 2009 | Nikon D90 Body Only Digital Camera
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
1,086 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
