Question about Texas Instruments TI-89 Calculator
Error: Mem I and trying to do a simple algebra problem using the solve function, however when i hit enter all i get is error: mem. I've already tried resetting my ram memory, it says i have 193936 free for ram and 2686896 free for flash rom. why does it keep spitting out error memory?
  • 10,865 Answers
Remove the battery to reset everything
Posted on Jun 25, 2009
TI 89
Remove battery from calculator and put it again. Then type in HOME 2nd F1 and 2:NewProb and ENTER. Try to solve any equations now. It may be resolve problem!
Posted: Stevan Milanovic
Nov 25, 2011 | Texas Instruments TI-89 Calculator
When I attempt to use hyperbolic functions for complex numbers i get a domain error
Have you checked the calculator's manual to see if the calculator is able (natively) to handle functions of a complex argument. It is able to handle simple algebra with complex numbers, powers, roots, solving a polynomial equation.
For this calculator, the hyperbolic functions must have a real argument otherwise you get a error. But just to make sure, try the exponential function with i (imaginary unit) as argument. If it comes back with a domain error you have your answer.
Apr 06, 2011 | Texas Instruments TI-89 Calculator
How do I set it to factory default settings? When I want to graph or want to do a zoom fit I get a ERR:SYNTAX 1:quit
Seems unlikely that you get a syntax error for both graphing and Zooming. Probably the error is in the function you are trying to graph.
To reset the RAM,
Press [2nd]MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared.
Press [CLEAR] button to erase the above message.
Once Ram is cleared, open the [Y=] function editor and at the Y1= line, enter [X,T, theta, n] key or [ALPHA][X], to draw the simple function Y1=X.
If that works, that means your calculator is OK.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Gives error memory message when tries to change
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Texas Instruments TI-84 Plus Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
S 10 lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 17, 2009 | Nikon COOLPIX L10 Digital Camera
SONY NWWM MEM AAD2 mp3 walkman, format error
my SONY NWWM MEM AAD2 mp3 walkman, 1 gb tells me format error when ever I try to change menus and will not play music, can you help me ?
Jul 07, 2009 | Sony Walkman NWZ-B135 MP3 Player
GE 5.8 mod 25922fe1-a
hit the # you want then hit the mem button. Enter the name, hit mem again, then enter number, hit mem again and will be saved
Apr 18, 2008 | GE 25861GE3 Twin Cordless Phone
TI-83 plus graphing calculator
This can easily be fixed. An Archived program can't be deleted or run. So you just have to unarchive it. hit "2nd" then "+" then go down to where it says "Mem Mgmt/Del" and hit enter. then hit all. There should be a "*" next to the program you can't run. now just hit enter and in a couple seconds it will be unarchived and the * will go away. Then you can delete or run that program. Hope this helps alot. Good luck
Jan 04, 2008 | Texas Instruments TI-83 Plus Calculator
Can't delete apps
try to delete the application after going to the main menu-tools-manager-from there you can delete the applications..or if the applications is in memory card than you can delete the application through the memory card reader
Oct 16, 2007 | Nokia 6600
Texas Instruments TI-89 Calculator Logo
250 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
