Question about Linksys Computers & Internet
Hello, I have been trying to get my linksys wireless N Gigabit router by reseting it as well as the modem. It is showing that there is no internet connection when it is hooked up, but when the internet is hooked directly to the computer the internet works. Can someone help me to fix this problem with the router. Thanks a lot!
  • wpfranks Jun 25, 2009
    Unfortunately when i tried the step by step guide you wrote me the wireless access still seems to not be working. I have also tried to use the linksys easylink advisor to try an sort this issue out but i have not had any luck there either.
    The easylink advisor states that the home connection is OK but the internet status not connected. One thing that i found strange is that the image of the router has changed and shows an older model of a linksys router with the name "gateway" above it whereas before there was an image of the same router. Thanks again for your time.
    President:
  • 392 Answers
Then try confuguring the DNS servers exactly in router.
Posted on Jun 25, 2009
  • 13,433 Answers
First reset the wireless completely by holding down the reset button for 30 seconds, this will restore it to factory defaults.
Now connect the modem to the wireless, on the uplink / internet / WAN / UP port that is separate from the other 4 ports that it may have.
wait 5 minutes and the wireless should configure itself automatically to give access to any wireless or wired computers that you connect to it.
Ones that is done you may want to set a password and a protection on the wireless so other people don't get on it.
Get Connected - Wireless Router Set up Video:
Which are the best Wireless Routers under $200?
Some of the best wireless routers available under $200 are:-
? Linksys WRT1900ACS Dual-Band Wi-Fi Gigabit Router
? ASUS RT-AC68U Wireless AC1900 Dual-Band Gigabit Router
? TP-Link AC1900 Wireless Dual-Band Gigabit Router
? NETGEAR AC1750 Wi-Fi Cable Modem Router
? TP-Link Archer C7 AC1750 Wireless Router
You can check and compare these wireless routers at:
Best Wireless Routers 2017 Reviews and Comparison
Jan 07, 2017 | Best Computers & Internet
Scientific atlanta modem is not showing that it is connected to my linksys wireless router
Seems to be that you have cable modem from Scientific atlanta.
  1. Turn off the modem and the router.
  2. Connect the modem to router with ethernet cable on internet port
  3. and computer to router's port no 1.
  4. power up your modem and wait for 2 minutes
  5. then power up your router and wait for 2 minutes and try to go online on computer.
  6. If not , then reset your linksys router by pressing your reset button at the back of the router with help of a pen for 10 sec.
  7. then follow the steps again 1 to 5
  8. try to go online.
  9. if still not , the open up a browser on computer
  10. type 192.168.1.1 in the address bar and hit enter on the key board
  11. leave the user name blank and type admin in the password box
  12. click on subtab of mac address clone under set up tab
  13. click on enable and click on clone my pc's mac tab.
  14. then click on save settings.
  15. and follow the step 1 to 5.
May 02, 2014 | Linksys Wireless-G WRT54G Router
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Not connecting to internet
You will need to reset your modem or have your internet service reset. When you have a PC connected directly to the modem the modem locks on to the NIC MAC address and will not assigin a pubilc IP address to the Linksys router until the modem is reset. I hope this helps.
Apr 13, 2010 | Linksys Wireless-G Broadband Router
I can connected to my linksys, but the the linksys
there is nothing issue with the linksys ist chk the ipaddress which u had provided to the modem and router is in same serious for eg: if ur modem is in 192.168.1.1 ten provide ur router ip as 192.168.0.1 and also chk whether the connection type is in PPPoE and also chk whether u r able to browse through modem which is provided by the ISP....
Feb 18, 2010 | Linksys Cable Modem
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
My router shows no connectivity.
Take your ethernet cable from the wan port and plug it into the lan port.
Nov 16, 2009 | Linksys Wireless-G WRT54GS Router...
Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Feb 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
I cant get my new wireless N linksys WRT310N router to work
First reset the router by pressing the reset button for 15 seconds and after resetting it run the setup CD fo it to reconfigure the router, if you don't have the setup CD better contact Linksys tech support number and let a tech walk you through in manually configuring the router, this is the number for Linksys 800-3267114...........
Jun 18, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Computers & Internet Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
