Question about RCA R52WH73 Projection Television
I dont know how to get the blue green and red lines off
I dont know how to get in the configuration to fix it
  • RCA Master
  • 8,617 Answers
You can get the RCA ITC222 convergence and geometry CD at the following link which takes you step by step through the adjustment procedures with photos. Its listed under instructional CDs
www.tvrepairkits.net
Posted on Jun 25, 2009
My rear projection tv used to have green lines , now the color seems off and now its blue lines... How do i fix it. Color going out??
If colors are skewed or looks 3d it is a convergence problem.
Some sets when the convergence grid is called up will have green lines--green is fixed and red/blue adjusted to it.
To tell you how to fix I need to know brand and model number.
These are typical convergence problems--no two sets will look exactly the same.
May 16, 2012 | Televison & Video
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Dont have the remote and blue, green, red lines dont align w/ pic
Convergence problem - a tech may decide to change the convergence ICs
May 27, 2010 | Philips 60PP9352 60" Rear Projection...
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
RCA R52WH73 Projection Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
