Question about Sharp Aquos LC-32D40U Television
Power light goes on. then "please wait". then nothing
  • heartky Jun 25, 2009
    First solution didn't work.
    Second solution simply indicates a TV repairman is necessary unless I want to take the set apart myself.
    I unplugged the TV overnight. The next morning it went past the "wait" and showed the input screen when I pressed the remote. After selecting the appropriate input the set worked. Thanks.
    SGE
  • 15,935 Answers
I am sorry to hear you are having this type of trouble. It is nothing you are doing wrong.
From what you have typed....you most likely have a poor solder connection or an essential chip needs resetting.
First try a hard rest by unplugging the unit for a minimum of 6 hours, then plug it back in and try again...quite often this removes the "quirks" these LCD's have.
If this doesn't work, then by the way you have described it getting worse it may very well be a poor solder connection...
Over time the solder connections can develop a hairline fracture . This is what I believe is happening to your TV somewhere in the power supply or video board if the reset fails to remedy your problem.
When this continues to happen it can create a small arc and surge voltage into surrounding components and actually damage them so it is best to have the problem resolved before components are damaged such as a capacitor or other essential component in your television.
This would be then be a component or board failure which must be addressed by a professional technician.
Unfortunately your warranty is only good for one year so the a repair cost would not be covered by Sharp if older than 1 year.
The board diagnosis and repair of a problem like this usually runs between about $200-$350 depending on your location, extent of damage, and will be on the higher end if you call for in home service.
TV repairs should only be attempted by trained individuals - as there are potentially lethal amounts of electricity stored inside which needs proper discharge before repair work can begin.
I HIGHLY reccomend letting a professional diagnose your set.
Unfortunately, there is no simple end-user fix.
Thanks for using FixYa!!
Posted on Jun 25, 2009
    President:
  • 1,197 Answers
  • Unplug the AC power cord of TV set to force power off.
  • While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. This should hopefully clear the problem.
  • Posted on Jun 25, 2009
    • SAM JAYANTH CHANDRASEKAR
      hi this is iversh again......
      if the above solution doesnt work....then you most likely have a poor solder connection
      or an essential chip needs resetting. First try a hard rest by
      try again...quite often this removes the "quirks" these LCD's have. If
      it may very well be a poor solder connection... Over time the solder
      the reset fails to remedy your problem. When this continues to happen
      component in your television. This would be then be a component or
      Unfortunately your warranty was only good for one year so the a repair
      cost would not be covered by Sharp. The board diagnosis and repair of a
      call for in home service. Normal 0 false false false MicrosoftInternetExplorer4 shud u wish to do the work on this urself... be sure to unplug everything and venture inside the tv.... look for loose solder connections and burnt out caps...... the capacitors usually have the specifications on them.. remove the burnt out ones and replace with new ones.... soldering inside the tv is not an easy job... so if ur really not sure abt what u need to do.. get a local repair guy... LCD tvs are very costly and we wud rather have a pro do the work for us...
      I hope this helps.
      if u feel i ve been of help ... kindly rate my service..... good luck and stay safe....
    Samsung LNS4041D has picture goes off
    Try to turn off, pull power cable out wait for a while then back power cable and turn power ON! If nothing happen power adapter must be changed!
    Jan 29, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
    Tv turns on, says please wait, then goes black and nothing happens
    The firmware to your TV might have corrupted. It should be upgraded.
    Sep 10, 2012 | Dynex DX-LCD32-09 LCD TV
    Yes i am tyler thank you trutech plv16320vm tv/monitor, will not come on,when you plug it in you get a red stand by light ,when you press the power on button. it goes off and nothing happens. or after u...
    I would have to say that you have bad capacitors in the power supply.Open the back of the TV,and look at the can shaped items called capacitors on the board with the power cord.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
    Tyler
    Mar 08, 2011 | TruTech PLV16320 Television
    Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen...
    take off : power cable , battery wait 5 min
    open the case take off the c-mos battery , wait 5 min
    mout everything , start the machine again , whit all connections , so you did a reset from your bios
    Apr 18, 2017 | Acer Aspire One AOA110-1113 Netbook
    Power light blinking
    if the power just shuts off for no reason when booted up,it may be the power source is on the way out ,it will work for a while, but keeps crashing, thats the first thing to replace
    also make sure you hear the fans working
    if it overheats it has a safty shutoff ,
    you can also use a house fan, aimed inside the computer while open, to rule out power source
    Jul 21, 2009 | Dell OptiPlex 170L PC Desktop
    Took cmos battery out
    The battery is dead... please replace it.
    this keeps all your system settings for start up.
    Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
    Televison & Video Logo
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
