Question about Refrigerators
Frig not cold enough - Refrigerators
  • Mark Nichols May 11, 2010
    evap fan motor running? any frost on the back of the freezer? let me know...
  • 221 Answers
If it's fridge/freezer and assuming the freezer is just fine then take a look to thermostat
If your unit is fridge only, then if compressor motor is working it will be low on gas, otherwise check the supply voltage line
Best of luck
Posted on Jun 25, 2009
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
I have a Frigidaire model# FRS26H7CSB1. THE FREEZER IS NOT GETTING COLD ENOUGH AND THE FRIG IS COLD BUT ONLY WHEN SET TO LOWEST TEMP SETTING. The metal frame/pillar between the freezer and frig is very...
The freezer not getting cold enough is defiantly due to the condenser fan motor not working. You would be best served to replace the fan motor with the correct part number though others will work, a small desk fan blowing in the back would work. As to the temperature issue in the refrigerator, you might have a bad t-stat.
Mar 12, 2013 | Frigidaire Refrigerators
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
Ice Maker inlet tube freezes up.
Try runnning a manual test of the defrost cycle, could be that you are not getting enough airflow to the frig side, while the frig side is calling for more cold. Becuase the frig side is calling for more cold, and not able to get there it is causing more airflow across the water tube.???
Aug 16, 2009 | Frigidaire Refrigerators
Frig / Freezer not blowing cold air.
your compressor could have chut off.
Jul 27, 2009 | Refrigerators
Ice in frig air vent
you did just fine defrosting it but, when you put everything back in don't overpack it, leave room for the air to circulate. the heat from the bottom unit will cause enough condensation to leak down the air vent and the it will refreeze blocking your vent again
Jul 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
