Question about Safe T Alert Carbon Monoxide Alarm Rv Trailer
I have a Class C motorhome. The unit is in storage and when I arrive to check on the motorhome, the alarm is going at low alarm or needs replacing noise. I had the unit checked as well as the motorhome. Everything is ok as a individual unit. I have to disconnect the unit in order to avoid running down the coach battery. What is the cause of the alarm. All the propane and unit is not running. We use the motorhome about once a month. Does the heat inside the unit have anything to do with it. I live in Phoenix Arizona. Thanks Chuck
  • 10,865 Answers
Hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Posted on Jun 25, 2009
I need simple pictures of the wiring diagram to rewire this motorhome including the engine in the generator so I can wire them together
Hi, will the shift lever move? If not you may a solinoid (shift antilock)that triggers when the brake pedal is engauged, If Thats your issue check your fuses. Also, you may have a def. switch on your break pedal. If the shiter moves and your rv dies, chk your trans. for low fluid. Hope that helps.
Aug 21, 2015 | Rv Motorhome Dual Co & Lp Gas Alarm...
Ford engine troubleshooting
Check for vacuum leaks first, could be old gas or clogged carburetor or fuel injectors, are all the plugs and wires good and clean ends, also look at the distributor cap and rotor, i would use a lil supreme gas in it to blow the bugs out too with a lil gas treatment in it
Mar 05, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
When starting alarm sounds and a dash light flashes tow
is the alarm an aftermarket alarm or an original Mercedes alarm ?
If its an aftermarket one it could be the self-powered battery cutting in because the battery voltage is getting too low and the siren thinks its being tampered with !
Check the condition of your car battery with a heavy duty discharge tester to see how low your battery voltage is going as you crank the starter motor , you possibly may need a new battery
Sep 15, 2013 | 1996 Mercedes-Benz C-Class
My motorhome 1986 chevy honey wont start fuel pump has no power
is it class "a" or class "c"motorhome----was the unit in a accident--check inertia switch
Nov 08, 2012 | Cars & Trucks
Jayco gas alarm going off when trying to use battery only
Check voltage of battery. Low battery will cause it to work erratically. Check voltage at connections of alarm. When your plugged in, converter will keep battery up to charge if working properly, but without being plugged in, battery voltage drops and alarm is basically trying to tell you it can't work properly unless it has proper voltage.
Jun 30, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
I cannot find the Horn under the bonnett of my Fiat Ducato Motorhome Can you Help Please
It is usually infront of the radiator -between it and the front of the vehicle -usually low down.
If it still works - sound it!
Check the wiring loom and look for a single wire going into that area to trace it.
Mar 15, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
Same alarm problem setting offf
As a camper myself, I know that one of the last thing we check is our Carbon Monoxide detectors in our unit. I had an old Class C motorhome with a CO detector that failed to alert me, and my kids got to the point of being nauseous. We were lucky to discover the problem.
A Carbon Monoxide Detector needs to be changed after 5 years because the sensor is designed only to last this long. If your unit needs to be changed, you can shop online on my website http://carbonmonoxidedetectoralarms.com/
Good luck and happy trails.
Jul 02, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Fuel pump does not work- 1999 ford super duty class a motorhome
Check your vehicles safeties. Your ECM is probably programed for engine shutdown if it senses low oil pressure or low coolant level. Do a preliminary check.
Apr 28, 2009 | 1999 Ford Super Duty F 550
Cannot set up the arrival alarm to a point
If you set your arrival alarm to .001 you are trying to hit a very small circle, only 6' in diameter and the odds of actually reaching that point are incredibly low so it's not likely the alarm will go off. Try setting your arrival alarm to .100 just to see if the arrival alarm works better.
When you set alarm to 15 second arrival you should see and hear an alarm, however, the slower you are going, the smaller the arrival circle gets, which means its gets harder to hit the area that triggers the alarm. 15 seconds is the default setting and I have found that it works fine at normal cruising speeds. If you are traveling very slowly, try bumping the arrival time up in 30 second increments to see if you can get an alarm.
When the alarm does go off, it is a very faint double beep which is hard to hear over the sound of wind and engines. I don't remember exactly how the visual arrival message appears but it is also very subtle. It appears either as a change to the menu bar at the bottom of the screen, or as a message box on the screen that dissappears very quickly. When I use that model I frequently miss the arrival alerts.
Jan 08, 2009 | Garmin GPSMAP 3210 GPS Receiver
Safe T Alert Carbon Monoxide Alarm Rv  Trailer Logo
519 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
