Question about Olympus Stylus 720 SW Digital Camera
Upgrading the software over the web
Can not upgrade
  • 2,985 Answers
Re: upgrading the software over the web
Remove the software from the computer and let ~Windows do the work.
You do not actually need supplied software to upload images into the computer from a camera
Widows can do it all itself.
If you are still having trouble there must be another reasom
Posted on Nov 06, 2007
0 characters
3 Points
I have Olympus Camedia Master 4.0. The program is not completely working the way it used to. Can I update to a Later program ? Lee.
Hi - You can download an upgrade to V. 4.3 but you must have a version of 4.X installed to do the upgrade.
You can download the software upgrade HERE.
Apr 15, 2011 | Olympus Digital Cameras
Problems downloading from camera using windows 7 - error message say windows XP required - is it possibel to upgrade software to be compatible with windows 7
If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download.
If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit for details.
Hope this help and be kind to rate please.
Jan 08, 2011 | Fuji FinePix F810 Digital Camera
I am running windows 7 and the software that came with the camera will not work. can you suggest something i can do. i have the 7.1 megapixal optical zoom digital camera
Go to your camera manufacturers web site, you've not mentioned it here, follow links to support and/or downloads. You should find any firmware or software upgrades you need there.
Apr 19, 2010 | Digital Cameras
Fuji A340
I had the same problem and downloaded a firmware upgrade from the Fuji web site and it now works in the camera.
Jul 18, 2008 | Fuji FinePix A340 Digital Camera
Software Upgrade
This error message indicates that the drivers are not digitally signed by Microsoft. In the event that you receive the error message referenced above, please continue with the install. Despite the fact that these particular drivers have not received the digital signature from Microsoft, they will work on Windows XP.
If you have difficulty installing the software from a direct update through the web, download the file first to your PC and then run it from there, if possible. Should you still have difficulties, try a clean boot of the camera software as explained here:
Hope that helps. Kindly take a moment to rate this solution a Fixya if you found it helpful. thanks.
Jun 08, 2008 | Kodak EasyShare Z7590 Digital Camera
Cannot download photos
Have you got Windows Vista on your computer? I have the same trouble - not solved yet. The instruction says to install the software first and then connect the camera - but the software-disc is not for vista yet - you have to download an upgrade for the eos-utility-program on the canon support-homepage. I did this too, but installed the upgrade after I had connected the camera already. Now I try it once more by uninstalling all and do the process completely in the correct order.
Greetings from Alex, Cologne.
P.S.: If you have the solution, please tell me (
Dec 14, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Installation and Usage Tips for the DiMAGE 7 Optional Enhancement Upgrade:
Taken from the DiMAGE 7 Upgrade Software Installation Pamphlet… Power Supply during Update: When performing the software update, please use a set of fully charged NI-MH (nickel hydrogen) batteries or the AC Adapter AC-1L or AC-2L (sold separately). When using the AC Adapter, be sure not to inadvertently disconnect the camera during the software updating procedure, otherwise the camera may be permanently damaged. Amendment to the DiMAGE 7 Upgrade Software manual… (Located on an insertion card within Upgrade Kit and Upgrade Firmware boxes) For Windows XP users: Do not copy the and ram.bin files directly from the CD-ROM to the CF card or the upgrade will not be executed correctly. First copy these two files onto the computer’s hard drive or desktop, and then copy them into the CF card. After upgrading: When the camera is turned to the playback mode, the no-image message appears and the images taken before the upgrade are not displayed. These images were placed in a folder with names ending in MLT03, the upgraded camera places images in folders ending in MLT14, see CompactFlash card folder organization in the DiMAGE 7 manual. To view images taken before the upgrade, select the appropriate folder in the custom 1 section of the setup menu. Refer to DiMAGE 7 manual for a description of this function. When using autofocus with the wide focus frame, the live image may freeze for an instant as the AF system determines the focus. This is because autofocus speed is increased
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
23 people viewed this question
Top Olympus Digital Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Digital Camera Expert? Answer questions, earn points and help others
