Question about Bose LifeStyle 5 Series-III CD Shelf System
No LED Display On The Bose Lifestyle Model 5 Music Center
My system works fine, but over time the LED display on the music center slowly faded to total darkness. What can I do to fix this problem?
Thanks,
Larry
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Posted on Dec 28, 2009
  • 1 more comment
  • aaodabashian Nov 18, 2010
    THIS WORKS!! My C19 was 33uF @ 25V. I replaced C14-17 with 100uF @ 63V and C19 with 33uF @ 63V. Of course replacement electrolytic caps can go over voltage with no problem...
  • John Smith
    John Smith Sep 16, 2011
    how did you open the case???
  • John Smith
    how do you open the case on this thing???
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Display screen led light wont come on
If the display has been gradually fading and is now unreadable, the fault is almost certainly loss of emission of the fluorescent display and it will need a replacement display module fitted (at a Bose Service Centre)
Is there any sign of characters showing in a darkened room?
If it has suddenly gone off, with all other radio features are working as normal, but prior to this the display was bright and clear, and the set has not been subjected to a fall or a sudden sharp impact of some kind, (which can crack the display module and cause it to fail) then the most likely possibilities are; a failed filament supply to the display module, a failed high tension supply rail to the display module, or loss of data feed to the display. It is also possible there may be a fault in the day/night brightness switching circuitry that has shut the display down completely. It is not possible to be more specific without seeing the unit, or even knowing which model it is I'm afraid.
Sep 04, 2014 | Bose Wave Music System CD Shelf System
Bose Lifestyle 12 Music Center DISPLAY display light number its not working anymore
I have had problems similar to this on many devices and it is usually a dud LED (light). You can technically de-solder the current LED and replace it but it's not a job for anybody without very good soldering skills.
Check to see if your system is still in warranty as this should be covered. Any electronics repair shop should be able to fix this for you.
May 08, 2011 | Bose Lifestyle 12 System
Intermittant brightness on trip computer display (LED panel). Sometimes the display works fine, other times the display is bright in the center and very dark around the edges. Today when I first turned...
Unfortuanatly,
This is a problem will all vehicles eventually. You will have to replace the display, if it bothers you or no longer operable. These typically have to be replaced at the dealer or body shop because they have to recertify your odometer reading. Sorry, I don't have better news.
Oct 02, 2010 | 2004 Volkswagen Passat
LCD not working
In most cases, these are VFD type not LCD type. In any case, when a VFD fades over time, that is aging.
Unfortunately, GE does not make the VFD displays available as a separate part, so the only option is to replace the entire "smart board". And they can be expensive at times. But if you do it yourself, you save a lot on labor.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JVC 27" AV27F803 Brightness fades to dark intermittently
I likely you have a loose conection in the crt board at the neck of the picture tube or a loose conection close to the high voltage transformer,I would suggest to tap the main board as well as the crt board with a wooden or rubber handle(not metal),be attentive were you tap to see if the set reacts ,if the set reacts you will need to resolder those places ,be carefull working on a set that is on while you do it,this should give some idea what the problem could be in case you want to call someone to help you with the repair.Let Us know if you need more information.
Nov 06, 2006 | JVC AV-27F803 27" TV
The monitor would not turn on. Only the orange LED does.
1. Make sure the monitor cable is fully plugged into the computer. 2. If the new monitor works fine, The connection between the previous monitor and the PC was bad. Reconnect the original monitor to the PC and make sure that the connection is snug. Tighten down the video connectors until they are snug. Try again. good luck..
Jan 06, 2006 | Hitachi CM772 19 in.CRT Conventional...
Bose LifeStyle 5 Series-III CD Shelf System Logo
5,228 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
