Trying to SyncThru to open in order to set up wireless Samsung printer
  • bkairies Jun 25, 2009
    This didn't help. The manual says I should type the printer's IP address in a web brouser and the SyncThru screen should appear. It's not happening. Do I need a new DHCP address?
    I am not satisfied with this process. How do I get a refund?
  • 583 Answers
The process is quite long to explain and put up over here so i will give you the link to step by step instructions:
just click the link below and scroll down a bit for instructions---
http://74.125.153.132/search?q=cache:mbWyBi5ie1AJ:www.samsungprinter.info/downloads/pdf/Networking%2520Printer%2520Installation%2520Guide%2520072008.pdf+SyncThru+to+open+in+order+to+set+up+wireless+Samsung+printer&cd=1&hl=en&ct=clnk&gl=in
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 25, 2009
  • livetech Jun 25, 2009
    yes in that case you will require a new dhcp address.
How do you do a factory reset on a Samsung ml-2525w printer?
If you have the install disc for the printer , you could delete from the hard drive and reinstall, If the Data is not installed in the printers memory this should work.
Mar 14, 2015 | Samsung ML-2525W Wireless Mono Laser...
Linux driver
Printing via USB:
  1. Get the samsungmfp- repository.
  2. Install samsungmfp-driver (samsungmfp-data will be installed automatically as a dependency).
  3. Go to Administration > Printing and delete previously created printer device(s).
  4. Connect printer via USB.
  5. Once new device has been created, go to Properties and change the Make and Model to Samsung SCX 4521F All-In-One.
For wireless printing:
  1. Connect to your printer. To get the IP address of your printer:
    1. Hold down on the printer power button for about 5 seconds; light will start to flash and when it begins to flash even faster let it go. This will print out the Configuration and Network Report.
    2. Locate the IP address on the Network Report and type it into your web browser.
  2. Once you are in the SyncThru Web Service, go to Network Settings and than to Wireless.
  3. Configure your Wireless Setting through the Wizard and follow the setup process (note that if your SSID contains space your network will not be displayed).
  4. Once the printer is connected to your LAN go to printer setting (Administration > Printing; Properties).
  5. Click the Change button for the Device URI.
  6. Go to Network Printer > Find Network Printer and type in the IP address of your printer.
  7. Apply the settings when it find the PASSTHRU. Device URI should looks something like this: lpd://[IP Address]/PASSTHRU.
Nov 04, 2013 | Samsung SCX 4521F All-In-One Laser Printer
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
My samsung clp-600n laser printer is missing the network menu, how do i find it when the menu goes from setup to information and not network!
Go to Samsung Download page and read the manual. See also the Software tab on the same page and install the appropriate SyncThru soft for your operating system. Dan
Sep 20, 2011 | Samsung CLP-600N Laser Printer
Hello, I got on my printer a Samsung CLP-315 always a red light <--> also when it print's it stops in the middle... Isn't there a reset buttom? Thank you
  1. Hello Charlotte, to reset your printer you have to do the following action
  1. The printer and the computer must be on
Hold down the "Stop" button (shaped like a triangle) for at least five seconds. A Network Configuration page should print out, showing the IP address of the printer. Even if it doesn't, the IP address with display on the printer monitor. Write it down.Open Internet Explorer and enter the IP address after "http://." As an Example, "http://192.168.1.107." And press "Enter." You will be taken to Samsung's SyncThru Web Service. you do not actually need to be connected to the Internet for this to work. on that page Click "Reset" and Click "Clear."
Aug 01, 2011 | Samsung CLP 315 Laser Printer
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
Default login for samsung syncthru
the username is
Admin
Password is
sec00000
Aug 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Default e-mail
you have to use SyncThru Web Service to set up the email accounts. I haven't done that but looked at it. I will probably go ahead and do it soon. Go to the Machine Settings Tab when you open the SyncThru Web Service page. You will see what needs to be done when you get to it. It looks involved. Good Luck. SyncThru Web Service comes with the software CD. You can probably download it from the Samsung site.
May 05, 2008 | Samsung CLX 3160fn All-In-One Printer
214 people viewed this question
k24674
jasbo
jasbo
