Question about Garmin Forerunner 305 GPS Receiver
Problem communicating with device (FR305)
I have similar problem - I get the same error, and my device/watch says transfer complete. I can transfer workouts and profile from training center to device, but not device to computer/TC. It only worked for about 2-3 workouts before I got this error - I have had the FR305 about a week.
I have tried: different usb port, stopping and starting ports, unplugging, restarting program and computer and device, repairing software, upgrading software
SOURCE: computer has a problem communicating with my forerunner 205
I just got off the phone with garmin tech. She helped me solve the problem. Here are the steps.
1. Go to http://www8.garmin.com/support/collection.jsp?product=010-00466-00
2. Download "Forerunner 205 Ver. 2.80 as of Nov 12, 2007", unzip it, and browse to the folder you unzip the files to.
3. Make sure your Forerunner is connected to your computer and turn it on. Drag file "048401000280.rgn" and drop it on "Updater.exe". A screen will pop up, select "USB" then click OK. Then wait till the process completes.
4. Go to the website on Step 1 and download "Training Center For Windows Ver. 3.3.4 as of Feb 29, 2008". Install it.
5. Run Training Center. At this point, I am able to send/receive data to my Forerunner.
Hope this helps!
Posted on Apr 02, 2008
Fix-Fox
  • 7 Answers
SOURCE: Garmin 305 not communicating with Training Center
I am new to the Garmin Edge 305, and started getting this problem yesterday. Indeed, yesterday it was the first time that I downloaded Courses.
I followed the Guest solution, deleted all new courses from my Garmin, and it now WORKs!!!!
Uploading my courses back again to the Garmin made the problem return back. I need some more work to identify the bad course.
Posted on Jul 05, 2008
KingDWS
  • 1606 Answers
SOURCE: Garmin GPS III Pilot to PC communication problem
If it were doing this just on the Vista machine I would say it was Vista related but since you are getting it from an xp machine as well the problem is either cable or the gps unit. You don;t say if this just started happening or ? If you can try out the cable on something else to make sure so you can eliminate it. About the only thing you can do is to make sure the port settings in the pilot are set correctly. Generally the slower the better if you are having communication problems as this makes the signal timing not as critical. Try 9600 baud to start. Make sure that the data bits are also set roght. This is the 8n1 or 7n1 thing you see. I can;t think of what the default is on the garmin but as long as both pc and garmin have speed, bits, parity, and stop but set the same they should talk.
Try to download from the unit as well as upload.Unfortunetly you can only change the speed and protocal or reset the unit. You won't be able to fix it if is a hardware thing. If you are using a USB to Serial adapter then I would say that is your problem or could be. Cheaper ones just don't work often on higher port speeds. You might want to try the gps on a pc with a actual serial port if you are using one. If it works then you should try a different brand of adapter or really slow down the speeds.
This won;t solve it unless you luck out but it should let you know where the problem is.
Dave
Posted on Mar 09, 2009
  • 84 Answers
SOURCE: Training Center won't save data
Are you using the original CD?
I had something similar happen when I upgraded my Wife's software. I ended up lossing all her history. I had to do a Windows restore to regain the information.
I then backed up her data and tried again. Same thing and the back up files would not work either.
If I used the original CD that came with the unit all was fine. But as soon as I tried the new version of the training center all was lost.
I didn't try to transfer data while all this was happening. I was too scared to try as I didn't want to lose what she had on the unit it'sself. So I'm not entirely sure if this will help you or not but definitely use the original CD that came with your unit.
Posted on Jun 08, 2009
SOURCE: I have a new Forerunner 305 and it transfered my
I've just experienced a similar issue for the first time since owning my Garmin 305 Forerunner. Slight difference in my circumstance is that the device itself doesn't show the activity in its history, despite having displayed apparently accurate readings during the activity iteself. Bizarre isuee, and although it's my first issue with this otherwise great device, it does destroy your faith in the unit.
Posted on Nov 24, 2009
What is code 434 mean?
This is an error normally generated in a network environment of printers where these is a problem in communication between the primary device and the receiving network device. You need to configure both ends to transmit and read data in a similar configuration.
Nov 01, 2015 | Office Equipment & Supplies
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
I am using arcsoft photoimpression software to use with my ion slide transfere. When I attempt to transfer pictures to my desktop I get that the utwainexe.exe has stopped... What am I to do?
This error message is caused by having multiple scanner devices connected to the PC which causes a communication error with Photo Impression and the PhotoMaker device. Disconnect any scanner devices and all in one printer devices from the PC and try again.
Thanks
Oct 09, 2010 | Computers & Internet
What does SCSI mean?
SCSI- Small Computer System Interface
It is a set of standards for physically connecting and transferring data between computers and peripheral devices.
May 29, 2010 | Microsoft Windows XP Professional
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
4gb Sandisk Cruzer USB drive on Windows XP SP3 When transferring over large files (1-3gb) I get an error message after about 3-4 minutes of transferring (roughly halfway through or near the end of...
WinXP uses its own driover for USB drives like this so as long as you have the latest updates installed that should be OK.
Make sure you are doing nothing else with the computer when transferring the file.
Check and make sure you have at least double the amount of free hard disk space as you are transferring.
Reformat the flash disk completely and tyhen run a checkdisk on it specifying to report and fix all errors.
Try defragmenting the hard drive so temporary files can be laid down contiguously.
See if there is a BIOS update for your motherboard.
May 17, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a new Forerunner 305 and it transfered my first workout to the computer but will no longer do so. The device says "Transfer Complete" however the computer states "There was a problem communicating...
Nov 08, 2009 | Garmin Forerunner 305 GPS Receiver
Transfer roller
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Oct 16, 2008 | Samsung CLP-500 Laser Printer
May 05, 2008 | Garmin Forerunner 305 GPS Receiver
Information to computer
I did have exactly the same problem.
I think what caused the unit to stop communicating with the computer was that somehow I switched to "multisport" mode.
I was cycling and somehow I switch to running.
The solution that worked for me was to download and install the "Webupdater" software from the Garmin site. This will update the firmware on your forerunner 305 (you need to be connected to the internet of course). After 5 to 7 minutes it will be done.
Then, download the latest Garmin "Training Center". This worked for me, I'm relieved now.
Apr 19, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
134 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
