Question about Garden
Toro Model 20070 will not start. I have spark,but mower won't fire up. I checked the spark plug and it seems OK.
  • 718 Answers
Check the gas and gas tank, you might have water in the gas.
Posted on Sep 26, 2009
My Toro mower Model 20070 will start but when I stop to empty my grass catcher it won't restart. I've put in a new air filter and checked the gap on my spark plug. The gas is new and I have added stabilizer. Starts fine the first time but then won't start. I have to wait several minutes to restart so I can continue cutting the grass.
Posted on Aug 01, 2011
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
What type of spark plug model 20070 toro mower
Best way is to go to their website with the model serial number to get the right spark plug... Good luck
Sep 11, 2012 | Garden
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro Model 20070 Electric start Lawn mower. It will not start. I changed the plug and filter. I pulled the plug and there appears to be no spark. When I turned it over I saw no spark. I guess my...
check your mower for interlock switches that might interupt spark for safety reasons.
A chute switch or something like that. Check your owners manual for troubleshooting.
Unplug the keyswitch and try pull starting to rule out a bad switch.
If it still doesnt have spark you might need a new coil.
The coil is right under the recoil cover and are fairly cheap.
A set of hand tools and $30-50 for the part should do it.
Good luck and be careful.
May 03, 2011 | Toro Power Lawn Mower
Toro GTS5 5.5 HP will not start
after attempting to start a few times;remove the spark plug and, check it if it is wet the engine is flooding dry the plug and, reinsert prime once and, attempt to start
if the plug is dry check the fuel filter
ground the plug while starting to check for spark
Sep 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
