I NEED TO FIND A 12 VOLT DC ADAPTER FIR MY Audiovox JE2043 20" TV. I LIVE IN CALGARY, ALBERTA, CANADA. I'VE GONE TO A FEW RETAILERS IN CALGARY AND HAVE NOT BEEN SUCCESSFUL
Try looking for a Jensen JE2043 with identical specs for the adapter: Input :100-240VAC (50-60Hz); Output : 12Vdc 6Amp. You can try ebay .
Alternately a 13.8/6A regulated power supply for communications equipment would also work. You simply need to hardwire the crown plug and red/black wires.
A lot of the adapters can be repaired (usually a cord damaged where it goes into the adapter or the connection at the set.
Two other things: adapter will have on it the voltage in and out--a pictorial showing what the voltage + and - on the end going to the TV is in DC volts---it will also have the wattage required for the TV.
Only reason to replace entire unit is they do not have the parts.
There's two options you can take. Both will likely cost you the same price of a new controller unless it's still covered under warranty. It will also take some time to repair so you might not get it back for a week or two.
There are two Sony Stores in Calgary:
1405 4 Street Sw, Calgary (403) 228-5205 24A-6455 Macleod Trail Sw, Calgary (403) 252-7221 You can also call up SCEA if you aren't looking to go outside. Their number is 1-800-345-7669.
