Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Pump cuts off when water gets on motor
Why does the motor shut off when I'm cleaning the filter? Does it get wet? why doesn't it cut off when it rains?
  • AO Smith Master
  • 1,383 Answers
CHECK VOLTAGE AT THE MOTOR.. SOUNDS LIKE YOU MIGHT HAVE LOSE WIRES AT THE MOTOR, TIMER, BREAKER OR A SWITCH IF YOU HAVE ONE I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Posted on Sep 11, 2010
Davey Water Pump XP350T with Torrium flow control won't run. We turn power on and it buzzes, then cuts out with a red fault light. Any ideas?
replace the failed start/run capacitor/s on the motor
town water although brown is filtered so unless a pipe has broken the problem will be the capacitor
May 30, 2016 | Washing Machines
How do I stop water from coming out of sprinkler heads after the pump cuts off
There will be water come out of the heads for a few min after they shut off to bleed the pressure off there is no way to stop it you might turn your system timer down a little
Sep 14, 2014 | Garden
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kenmore washer not draining
see the causes and remedies:
t spins, but doesn't pump
drain line is clogged+some sock inside remove+pump defective, if lines is not clogged.
It doesn't spin or pump
frozen pulley pump, replace,try to rotate manually, if donot replace
It pumps, but the water returns
improve the drain line, if exceed 4 inches cut off the excess
if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Hot water pours out, cold water trickles. This just started happening this week. Is there a pump that forces the water to move or is the problem more likely the hose is plugged? or is there another...
The dual water inlet valve cold side is just stopped up with sediment. There is a screen filter in the water hose where it connects to the water supply. Cut the water off and unscrew the hose and look in the end of it for the cone shaped filter and clean it out. If that doesn't fix the problem you may have to clean or replace the inlet valve which is at the other end of the hose. The hot water doesn't usually have a problem because any sediment has a chance to settle out in the hot water tank.
Jun 10, 2011 | Kenmore Washing Machines
Ryobi 7" wet saw. water
Direct the water on to the slate itself just ahead of the cut. When you spray the blade, centrifugal force causes the water to fly back off. Good luck!
Nov 07, 2010 | Garden
After hydroplaning into a ditch My Bronco will not start....have a new motor and Transmission...acts as if starved for fuel
The problem could be that the air filter has become wet, or water has entered an electrical control device in the engine compartment, or a wire connector or a bulk-head connector might have become loose or dis-connected, the fuse to the ECM or fuel pump might have blown out, or the fuel shut-off inertia switch has been tripped.
Check the fuse to the fuel pump and the fuel shut-off or "inertia" switch, usually located behind the passenger side kick panel, or it will sometimes be located under the carpet just under the heater assembly, and check the red reset button on the top to see if it has been tripped, and push the red button all the way down to see if it will reset. Here is an image of the inertia switch or fuel cut-off switch, and a diagram that shows the location of the fuel cut-off switch under the passenger side carpet to help assist you, and let me know if you require any further assistance.
Aug 08, 2010 | 1990 Ford Bronco
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
Motor starts and pump is not working. No water is flowing at all..what do i need to do?
Water is supposed to flow slightly through the pump without it running so disassemble the wand and cut on water supply, see if water comes out of the wand on-off handle. The motor does not have to be running. Got water flowing? YES - clean out the wand filter or nozzle hole. A partially clogged filter will prevent hi pressure activation.
NO? disassemble pump and clean out chamber paths.
Also - A pressure pump is not suppose to be running and not used for over ten minutes. The pump can overheat from lack of water passing through and damage the pump seals. A clogged wand is the same as not using it while you try to figger out why it doesn't have high pressure. I found my clogged filter and stopped up nozzle but haven't gotten my real high pressure back yet. Sears doesn't sell the valve seal kit but someone does.
May 04, 2009 | Garden
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
177 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
