Question about Maytag MSD2756G Side by Side Refrigerator
Ice maker not releasing ice
My ice maker is making ice but the port does not open to let the ice out of the door when i put a cup.
  • giftsanddeal Jun 25, 2009
    the path is clear of ice but the pad does not open
  • Maytag Master
  • 4,655 Answers
If your model is the model listed above your post it has a control board and is recommended that a service technician do the test. to find the solution. If this is something you feel you are qualified to handle I will send you the manual. Let me know. Sea Breeze
Posted on Jun 25, 2009
  • John Tripp
    John Tripp Jun 25, 2009
    My appoligies I did not want to answer over
    bwwatson
    Sea Breeze
  • 77 Answers
Froze up, its going to have a clog of ice between the basket it comes out of and the door. try to break it loose with an ice pick......be careful not to hurt yourself or the freezer.
Ge fridge not making ice I have water dis IT works fine I put one cup water in maker nothing could itbe the valva thanks
probably have frozen evap coil..turn off unit remove perishables leve refer door closed and freezer door open..thaw out for several hours..if you have a lot of water comming off you most certainly have ice up the coils..probably bad heater.defrost timer or board..good luck,RDS
Apr 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag refrigerator has an ice maker that will not shoot out ice. the ice maker will make ice and send ice to the door where it comes out but the door needs more pressure in order for it to open. I can...
the door has a solonoid the opens it and is not working . ice does not put the pressure on the door. look for bad sol. or linkage to sol . or bad pc board that tell it to open .. ****
Jan 12, 2010 | Maytag 25.6 cu. ft. Side-By-Side...
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Maytag MCD2257KES ice maker shoot door does not open
Yes, the ice/water unit can be removed from the door to give access to the switch and solenoid that opens the ice door.
Dec 28, 2008 | Maytag MSD2656G Side by Side Refrigerator
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2756G Side by Side Refrigerator Logo
113 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
