Question about Samsung SGH-D900 Cellular Phone
USB Connection I am tto scared to force the little thin plug with the arrow on into the multimedia slot.  Please let me know the correct way of doing this before I screw it up. Thank you, Monica
  • 3 Answers
Try it so that the arrow is on the top and then it shoutd go in easily
Posted on Nov 17, 2007
GE Wireless keyboard #98615 instructions say to turn the ON button in the bottom of my keyboard. There is no on/off button
As far as I know there is no ON button on the GE 98615 Wireless Thin-Profile Keyboard. Unless is the ON configuration for the NumPad which you will find it in the BIOS.
I Hope this might help you with your GE 98615 Wireless Thin-Profile Keyboard.
1.- Plug the USB receiver into an available USB port of your PC, no required batteries.
2.- Insert the batteries with correct orientation into the battery compartment of the keyboard
Please NOTE:
(a) This wireless keyboard provides factory preset connection channels and enables Plug and Play function. (b) This keyboard does not require changing connection ID as there is no ID button on the receiver. (c) When this wireless set encounters radio interference, keyboard will automatically change to a clean channel respectively. (d) Manually changing connection ID is not necessary.
Sep 01, 2011 | Computers & Internet
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
Where on the camera do you plug in the plug for the computer, i know where the usb goes on the computer but the plug I got does not fit in the camera
Your camera requires a "U8" type USB cable to connect between the standard USB port on your computer and the U8 jack on the camera.
A "U8" style USB cable & jack.
The U8 USB is similar in appearance to the USB "Mini" or USB "A" style jack. But will not mate to any other jack besides the U8 style. A typical USB Mini or "A" is shown below for comparison.
The camera shipped with the correct cable, but you probably didn;t notice there was a difference between it and other USB Mini cables - and simply grabbed the wrong one.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 07, 2011 | Kodak EasyShare C643 Digital Camera
New build turned on power no beeps no video nothing but fans
make sure that your little speaker is plugged in to the correct pins. This gets many people every time. If the speaker isn't plugged into the correct slot you're definitely not going to get anything to work...yeah i know...a silly speaker...you can have quite a few things plugged incorrectly and things will still work but if you have the speaker plugged into the wrong one...then ur dead in the water...find the little cylindrical speaker and try plugging it into a different slot...really look on that board for it. Should be labeled JFP2..connect the speaker to the 4 pin side of that 7 pin connection.
Dec 21, 2009 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
When I plug my PSP (type A) into my PC (Windows XP
Make sure you follow these steps, this will allow the PC to recognize the PSP:
First make sure you have a USB cable that looks like this:
Then do this:
  1. Connect the mini connector to the top of your PSP and the other end of the cable into a USB slot on your PC. For the best perfornance, connect your PSP to a USB 2.0 slot.
  2. Make sure the PSP is on.
  3. Scroll to the 'Settings' menu by pressing the left arrow on the PSP.
  4. Select 'USB Connection' using the up and down arrows on the control pad.
  5. Press the 'X' button.
  6. Your PC should detect the PSP device, and show it in Explorer as a new drive (for example, 'F:').
Nov 28, 2009 | Sony PlayStation Portable (PSP) Console
How do I attach the front USB, speaker and mic of the case to MB?
Follow that arrows on the pictures. Plug the USB Front Panel Cable.
Aug 06, 2009 | Intel Motherboard
Just hooked up, doesn't work
Well, the old round plugs with the tiny little prongs inside are called PS2 (named after the IBM personal System 2 from wayyyy back in the day). anyhow, the PS2 style requires that the pins be aligned properly, and not bent. they are circular and there is a plastic bar in the center that should go into a plastic slot on the plug in. also, make sure the arrow is facing the "top" of the motherboard. (if it is a tower pc then the top of the board will be on the left side of the machine, if it is a desktop machine, then the top of the board will face the top of the machine). Please do not force it. its glides in easily if facing the correct direction. ALSO, one small 'detail': older PS2 style devices are not "hot swappable" which means the machine must be off when you add or remove them. once you restart, the computer will find them and activate them.
Jul 03, 2009 | E-Machines AAFQ50400000K0 Keyboard
I cant sync my madcatz ps3 wireless controller
try to plug it in and then press the ps button or let it sit for a little bit while plugged in and then try it
May 27, 2009 | Sony Playstation 3 (PS3) Console
How to load mp3
You need a cord that goes from your phone to the pc. The end that goes in to the pc is a USB connection. It is wide and thin and you will see the slots (usually in back). There may be slots in front depending on your tower. That's it.
Dec 29, 2008 | Nokia 6600
How do I connect Nikon Coolpix 3200 to a pc?
You need USB cable to attache Nikon camera with your PC in USB port. Picture shows USB port in your camera and PC has USB ports at rear and possibly at front too.
Aug 24, 2008 | Cameras
Samsung SGH-D900 Cellular Phone Logo
16 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
