Question about 3Com U.S. Robotics Voice Message Pro (045625-01) Modem
Searching for embarq 660 series m modem driver
My brand new pc with windows xp SP2 doesn't see the 660 embarq modem, can anybody hook me up with a soft for that modem plz?
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
I have install windows xp sp11 so i cant access internet becouse i wanna install modem driver plss tell me how can i install what is the drivers name
use another computer to download SP2 onto CD or a USB drive, then copy onto your XP SP1, it will provide more dirvers. Be sure and remove the modem before you start all of this. And also look at Computer, Drivers and uninstall any drivers for your modem model. Install SP2 and do windows update. I would also recommend after this to get SP3.
Last step if Windows doesn't have the driver is to get the driver from the manufactures website. Some modems have specific PC software beyond the driver to use it.
Jul 10, 2011 | Computers & Internet
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Feb 12, 2010 | Belkin (F5D8231-4) Wireless Router...
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
EMbarq/Zyxel 660R/eHarmony/Windows Don't Play together well
Upgrade to the latest firmware on the modem, disable the modem firewall, or bridging the modem will resolve this
Sep 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Router not working
has it worked before? if so, try to power cycle the devices by turning off everything. then turn on your modem first, wait for the lights to turn on on the modem before powering on the router. check if you're online
but if the router is for initial setup, you can try to run the cd first and follow the instructions. you need to make sure also that you can access the internet directly from your modem
hope this'll help you but if you still experience the same problem, just provide your ISP, the model of your modem and how are you connecting the devices
ciao!
Jul 11, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
Computers & Internet Logo
539 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
