I thread the thread to the bobbin and when I move the slide over and press the foot pedal..it just tries to turn then stops. But the needle that is not supposed to move ..moves. Then it stops. What do I do?
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
SOURCE: My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Sounds like the motor might be having problems. I would take it in for a proper servicing.
