Question about Sharp 32F640 32" TV
Sharp TV - 32LW92H - Zoomed in
I think I have pressed a button on the remote or something but all of a sudden it is in Zoom mode. No matter what I do I can not seem to get it out of Zoom mode. I have lost the user manual and my remote is tempermental but apart from that it is a lovely picture. It chops of heads or just the top/bottom of picture - Again I think this is because it is Zoomed in one notch. Please advice I would be so grateful!
  • 1 more comment
  • Anonymous Jun 02, 2008
    i have a lc-46d82u sharp tv it will automatically jump to the zoom mode
  • kaysie101 Dec 04, 2008
    yes i have the exact same problem i cant see the top and bottom of my screen and both side as warped in
    yes
    Novelist:
  • 192 Answers
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Nov 05, 2007
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
I am unable to set the Digital Zoom to On, in my Canon G12. The Digital Zoom Option in the Camera Menu always seems to stay blanked out no matter what I do. Discussions with fellow G12 owners did not...
The digital zoom setting is only available when the aspect ratio is set to 4:3. The setting is accessible by pressing the 'func.set' button in shooting mode.
Mar 17, 2011 | Canon G12 Digital Camera
My tv screen is zoomed in how to zoom out
  1. Check the TV to see if it has a ZOOM / WIDE option or control for adjusting the aspect ratio; if so, try setting it toNORMAL .
  2. NOTES:
    • If there is a SCREEN MODE button on the TV remote control, you can press this button until NORMAL is selected.
  3. If using a cable/satellite set-top box, DVD player or digital video recorder, check the device for aspect ratio controls and try selecting a different display option.
Jan 16, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Jvc 57 inch tv. kid did something to change picture size. now too large and bottom is cut off. aspect button on remote when pressed shows a red circle with a line through it.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Apr 13, 2010 | JVC AV-28-BD-5-Bl 28" TV
Zoomed out Picture
button 19
ASPECT Cycles through Wide mode settings:
NORMAL/FULL/WIDE/ZOOM.
PIP Turns PIP/POP on and off.
Mar 25, 2010 | Polaroid FLM-2632 Television
Picture Zoomed in too much, no zoom button
I had the same problem after plugging my pc into the pc-in socket. The problem happened with the scart connections after.
I solved it by turning the tv off/on from the wall plug socket.
Mar 06, 2010 | Televison & Video
My remote suddenly stopped working.
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Jul 16, 2009 | Sony RDR-VXD655 Recorder
Sharp 32F640 32" TV Logo
1,031 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
