Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Remote mailfunction We've had the system for about a year now, and until yesterday, its been acting weird. When I press the remote, the garage won't open. So I reset the machine, and re-enter the remote's code, it works once, but the next time i press it, it doesn't work again. I've tried resetting and re-entering 5 times, but no luck. Any suggestions?
Garage door will go down and stop and go back works sometimes when you hold button the whole time pain in the neck
Posted on Aug 02, 2009
    President:
  • 1,114 Answers
Sounds like a bad board in the main drive unit. If you call their customer service, they will walk you thru a short troubleshoot, then more than likely send you a new board. The phone # is 630-279-3600 located in illinois. have your model # and serial # ready. serial # will be on the PC board of the main unit. Hope this helps
Posted on Jun 25, 2009
I have a 2014 Chevy Silverado and want to unprogram or reset the remote garage door opener. I don't see anything anywhere about resetting it. Should I remove the positive battery lead for awhile?
See the link section 5- page 54 for the procedure.
Universal Remote System Operation Using the Universal Remote System Press and hold the appropriate Universal Remote system button for at least one-half second. The indicator light will come on while the signal is being transmitted. Erasing Universal Remote System Buttons Erase all programmed buttons when vehicle ownership is terminated. To erase: 1. Press and hold the two outside buttons until the indicator light begins to flash. This should take about 10 seconds. 2. Release both buttons.
Reprogramming a Single Universal Remote System Button
To reprogram any of the system buttons: 1. Press and hold any one of the buttons. Do not release the button. 2. The indicator light will begin to flash after 20 seconds. Without releasing the button, proceed with Step 1 under "Programming the Universal Remote System.
Hope this helps?
https://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/2k14silverado.pdf
Oct 03, 2016 | Building Materials
How do you connect the home link garage control to your car & garage?
Things You'll Need
  • Remote garage door opener
Suggest Edits
    • 1
      Turn your Chrysler vehicle off and press and hold the two outside buttons on your onboard opener system. Release the buttons once the red indicator light begins flashing. This will erase any previous codes programmed to your system.
    • 2
      Hold your garage door opener remote two inches away from the onboard system.
    • 3
      Press and hold the button you wish to program on your onboard system and the open button on your remote simultaneously. Release the buttons once the indicator light on the onboard system begins flashing.
    • 4
      Press the training button on your Chrysler's system until the light glows solid. If it does not glow solid, continue to the following steps.
    • 5
      Press the "learn" button on your garage door remote, located near the antenna wire on the back or side of the system, and return to your vehicle.
    • 6
      Press the training button on your on board system, hold it for two seconds and release. Repeat the press/hold/release step two more times and your remote will be programmed and ready for use.
Dec 10, 2011 | 2002 Chrysler Town & Country
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
Having trouble setting garage door opener to my 2004 trailblazer
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
Need to change the freqency on a lift master garage door
Chance are they set there remote when you were using yours. To reset your opener you need to clear all the codes on the back of your opener itself there is a square button purple or red depends on how old it is. Press and hold that button until the LCD light turns off. Press your remote to make sure it has stopped working. Then press the button again only for a sec until the light comes on and starts to flash then press your remote button. Repeat for each remote.
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
My car was stolen along with my garage opener remote
On the back of your opener motor unit is a small "learn" pushbutton. When you press it, an indicator light nearby comes on. Keep the button pressed until the light goes out (5 to 10 seconds) and all codes previously set will be erased. To reprogram the unit for the remotes you still have, press the "learn" button again but don't hold it down. While the indicator is lit, press the button on the remote to store its code. Repeat the process for each remote. If you also have an outside keypad the process is the same, just enter the new 4-digit code.
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
199 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
