Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony LCD tv
My tv has a blue cloudy color around the edges of the screen mainly on the right side and somewhat on the top and bottom. thhe size and shape seem to change day to day. is it something that can be fixed at a low cost or is it junk. the tv is about three year old.
have wega 50we610 for two years noticed in last two weeks a cloudy blue tinge has appeared at bottom near right corner of screen. seems to be there all the time no matter what channel
  • 1 more comment
  • ri43210 Nov 07, 2007
    A similar problem, except that mine spread down and across half the screen. I also notice that the screen is not totally black where black is being projected...the whole screen seems to be picking up a low level of scattered light that does not allow the black and reduces the contrast. I also see what appeared to be 4-5 blue dots scattered around near the center of the screen and they have now multiplied to about 12.
  • Anonymous Nov 13, 2007
    we ve been having trouble with our screen , its like a yellow thumb print on the bottom left hand side of the screen and like a blue waterfall effect on the top of the screen
  • Anonymous Mar 24, 2014
    Blue line right side top to bottom
    Problem Solver:
  • 22 Answers
I guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Posted on Nov 05, 2007
Sanyo DP46848 im stumped lol... with nothing connected ( aka ) cable and or any other components .. just plug and turn on .. the screen has a solid blue bar from top to bottom with small white lines in...
Although you have not posted a picture, I believe you may have a screen or LCD panel problem, the panels have film connections that go from the t-con module, through the panel control pc boards then through thinn film connectors from the lcd screen. Likely this is the problem.
Oct 29, 2013 | Sanyo DP46848 LCD TV
I have a KDF-55XS955 .A yellow splotch just appeared over night on the top right hand side. Starts about 1' top right corner, about 6" wide and the progress down the right side 3-4" from the edge...
This is a common problem for SONY LCD projection TVs. The problem is burned evaporated metal layer on the RGB color lenses. To fix it, you have to purchase a new light engine.
Sep 02, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Jun 02, 2009 | Toshiba REGZA 47HL167 TV
Cloud like image around edges of screen
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Apr 04, 2009 | Philips 60PP9352 60" Rear Projection...
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Blue edge from top to bottom
Its problem of blue LCD in light engine.
Sony will repair it with very little money or even free up to Dec 31, 2008
Click Sony Support for details...hurry up as time is running.
Good luck.
Dec 23, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Sony LCD tv
you are going to need an optical assy (A-1084-658-A) and it runs about $1257.50
Oct 13, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655 (LCD 42 inch)
I have the exact same problem with my 42" LCD HDTV. When I called Sony "customer support" they told me NOTHING. However, I began researching this issue and found out that Sony knows all about this problem. It's a part called the "Optical Block" and THEY are supposed to reimburse you for the repair! The claim form is on the Sony Website. Here's the link: Look inside the yellow box on the right and click on: Additional service coverage information for your TV (scribble / line pattern on screen) Hope this helps you!!
Apr 28, 2007 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
404 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
